2 Replies Latest reply on Dec 21, 2011 10:28 AM by Carol L. Frampton
    <s:datagrid> and drawRowBackground
    kaissun Level 1
      hi,
      the drawRowBackground method is concerned with <mx:DataGrid> component.
      My goal is to migrate my flex 3.2 application to a flex 4.5 application.
      So it's necessary to use <s:DataGrid> component. But the drawRowBackground does not exist.
      Could you give me a solution to have the same features of this method ? thanks.
      this is the actionScript code :
      override protected function drawRowBackground(s:Sprite, rowIndex:int, y:Number, height:Number, color:uint, dataIndex:int):void
                  if (rowIndex == 11)
                         color=00FBEAD5;
                  super.drawRowBackground(s, rowIndex, y, height, color, dataIndex);
      Thanks in advance
        • 1. Re: <s:datagrid> and drawRowBackground
          supersonicecho Level 2
          Assuming your itemRenderers support the backgroundColor property (E.G. BorderContainer), this could work:
          private function drawRowBackground(rowIndex, color):void
               var renderer:* = dataGroup.getElementAtIndex(rowIndex);
               renderer.setStyle("backgroundColor", color);
          This solution sucks though.  A much better solution would be to create custom item renderers/skin states for your dataGroup.  I suggest you read up on Spark datagroups and item renderers.  It is more work to customize but you have immense freedom.
          • 2. Re: <s:datagrid> and drawRowBackground
            Carol L. Frampton Level 2
            Look at the alternatingRowColorsBackground Component in the DataGrid skin.  You can override the prepareGridVisualElement method to draw the 11th row the color you want.
            Carol
