3 Replies Latest reply on Dec 21, 2011 12:47 AM by Claudiu Ursica
    isItemHighlighted isItemSelected flex 4
    kaissun Level 1
      HI,
      my goal is to migrate my application from flex 3.2 to flex 4.5.
      So, i have the following properties in the actionScript part :
      dataGrid.isItemSelected(data)
      dataGrid.isItemHighlighted(data)
      But spark.components.DataGrid component we don't have these properties, could you give me please the equivalent of these two properties ?
      Thanks in advance
        • 1. Re: isItemHighlighted isItemSelected flex 4
          Flex harUI Adobe Employee
          You can check the currentState of the renderer.
          • 2. Re: isItemHighlighted isItemSelected flex 4
            kaissun Level 1
            How ? i don't understand what you mean. Can you give me some code ?
            • 3. Re: isItemHighlighted isItemSelected flex 4
              Claudiu Ursica Level 4
              Presumably you are using a custom itemRenderer and it extends ItemRenderer you have these states out of the box:
                  protected function getCurrentRendererState():String
                      // this code is pretty confusing without multi-dimensional states, but it's
                      // defined in order of precedence.
                      if (dragging && hasState("dragging"))
                          return "dragging";
                      if (selected && down && hasState("downAndSelected"))
                          return "downAndSelected";
                      if (selected && showsCaret && hasState("selectedAndShowsCaret"))
                          return "selectedAndShowsCaret";
                      if (hovered && showsCaret && hasState("hoveredAndShowsCaret"))
                          return "hoveredAndShowsCaret";
                      if (showsCaret && hasState("normalAndShowsCaret"))
                          return "normalAndShowsCaret";
                      if (down && hasState("down"))
                          return "down";
                      if (selected && hasState("selected"))
                          return "selected";
                      if (hovered && hasState("hovered"))
                          return "hovered";
                      if (hasState("normal"))
                          return "normal";
                      // If none of the above states are defined in the item renderer,
                      // we return currentState, so we don't change the state just
                      // in case the developer put the item renderer into its
                      // own custom state.
                      return currentState;
              So in your code you ca check whatever state is the renderer in, that will tell you if the item is selected or not.
              C
