1 Reply Latest reply on Dec 21, 2011 7:42 AM by absqua
    JPEG export preferences problems
      I have indesig cs5.5 and tryed set export resolution and jpeg color space. But in my computer i can't because this properties don't existe.
      In other computer this script read ok.
      below the JPEG export preferences properties.
      The script
      tell application "Adobe InDesign CS5.5"
                tell JPEG export preferences
                          set JPEG export range to export range
                          set Exporting Spread to false
                          set Page String to "2"
                          set export resolution to 72
                          set jpeg color space to RGB
                          set JPEG Quality to low
                end tell
      end tell
      The properties
      class jpEr»:72, JPEG Quality:low, Page String:"2", JPEG export range:export range, JPEG Rendering style:baseline encoding, Exporting Spread:false, parent:application "Adobe InDesign CS5.5", object reference:JPEG export preferences of application "Adobe InDesign CS5.5"}
        • 1. Re: JPEG export preferences problems
          absqua Level 4
          What was resolution in CS4 became exportResolution in CS5 (and CS5.5). Is it possible you mapped "Adobe InDesign CS5.5" to a CS4 installation on the machine it doesn't work on?
          Also: I'm not an Applescript expert (or even really competent in it), so I'm probably going to embarrass myself, but... Have you tried copying and pasting the script's contents into a new file on the machine where it doesn't work rather than running the (compiled, or whatever) .scpt file?
