3 Replies Latest reply on Dec 21, 2011 12:33 PM by Ned Murphy
    Basic presentation template hangs using event listeners
    rhysacymro
      Hello
      I've got a 'powerpoint style' slideshow built in Flash CS5, AS3, using the basic template (ie as on frame 1 root to advance frames on cursor keys). All works perfectly until I get to a MC which has the following script (snippets):
      button_1.addEventListener(MouseEvent.CLICK, fl_ClickToGoToAndPlayFromFrame);
      function fl_ClickToGoToAndPlayFromFrame(event:MouseEvent):void
                gotoAndPlay(2);
      There are a number of these on the MC timeline to advance to different frames in sequence. All works perfectly, except that when it gets to the last frame. I press the cursor right to advance to the next root slide and it works. However this slide hangs... whatever the content. I deleted the AS on this MC and all works fine so it is definitely a conflict between the script above and the template frame control script:
      stage.addEventListener(KeyboardEvent.KEY_DOWN, fl_changeSlide);
      function fl_changeSlide(evt:KeyboardEvent):void
                if(evt.keyCode == 37) // LEFT
                          gotoAndStop(this.currentFrame-1);
                else if (evt.keyCode == 39 || evt.keyCode == 32) // RIGHT OR SPACE
                          gotoAndStop(this.currentFrame+1);
      stop();
      Any ideas. PS If I wait about a minute, it starts working again (ie the frames advance as normal).
      thanks in advance
      rhys
