0 Replies Latest reply on Dec 22, 2011 12:56 AM by amol bhandwale
    enable disable linkbar links in datagrid itemrenderer.
    amol bhandwale
      Hi All,
      I have to show the linkbar in datagrid column as a renderer and enable and disable the links according to attached documents codes.
      here are my sample code
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init();">
      <mx:Script>
          <![CDATA[
              import mx.collections.ArrayCollection;
              [Bindable]
                public var arrColl:ArrayCollection = new ArrayCollection();
                public function init():void{
                    arrColl.addItem(["1,2,3","1,2"]);
                    arrColl.addItem(["1,2,3", "1,3"]);
      </mx:Script>
          <mx:DataGrid id="dg" dataProvider="{arrColl}" width="200" height="500" x="510" y="168" >
              <mx:columns>
                  <mx:DataGridColumn  itemRenderer="assets.components.linkbarItemRenderer"  />
              </mx:columns>
          </mx:DataGrid>
      </mx:Application>
      My item renderer linkbarItemRenderer.mxml as
      <mx:HBox xmlns:mx="http://www.adobe.com/2006/mxml" width="100%" height="100%" creationComplete="init();" >
      <mx:Script>
          <![CDATA[
              import mx.controls.LinkButton;
              import mx.controls.Alert;
              [Bindable] public var arrColl : ArrayCollection = new ArrayCollection();
              public var arrDocType : ArrayCollection = new ArrayCollection([{data:"1" , label:"AP"},{data:"2" , label:"AR"},{data:"3" , label:"BOL"}]);
              public var attDoccodes : Array;
                  try
                      var requiredDoc :String = data[0];
                      var attachDoc : String = data[1];
                      var reqDocCodes :Array =  requiredDoc.split(",");
                      attDoccodes = attachDoc.split(",");
                      if(reqDocCodes != null)
                          //add the links of required documents.
                          for(var i:int = 0 ; i<reqDocCodes.length; i++ )
                              var obj:Object = new Object();
                              for(var j : int = 0; j < arrDocType.length; j++)
                                  if(arrDocType.getItemAt(j).data == reqDocCodes[i])
                                      obj.label = arrDocType.getItemAt(j).label;
                                      obj.data  = reqDocCodes[i];
                              arrColl.addItem(obj);
                      callLater(enableDisalbeLinks);
                  catch(error:Error)
                      Alert.show("error ::"+error.getStackTrace());
              public function enableDisalbeLinks():void
                  try
                      //disable all links first
                      for(var q:int=0; q< arrColl.length; q++)
                          LinkButton(linkBarId.getChildAt(q)).enabled = false;
                      if(attDoccodes != null)
                          for(var k:int = 0; k<attDoccodes.length; k++)
                              for(var l:int = 0 ; l<arrColl.length; l++)
                                  if(arrColl.getItemAt(l).data == attDoccodes[k])
                                      LinkButton(linkBarId.getChildAt(l)).enabled = true;
                  catch(error:Error)
      </mx:Script>
              <mx:LinkBar id="linkBarId" dataProvider="{arrColl}" />
      </mx:HBox>
      It renderes the link in correct form in datagrid first time.when i scroll the datagrid the rows are miss up with each other and links are not shown propers in enable/disable format.
      Amol.
