1 Reply Latest reply on Jan 25, 2012 5:43 AM by ommm42
    data Tip in Tooltips of sparks DataGrid
    Frank F._
      i have a strage behavior with my sparks Datagrid.
      In my Application, i have a Button which opens a Popup containing a TitleWindow. In the TitleWindow  there is a DataGrid with the following code:
      <s:Scroller maxHeight="350" width="100%">
      <s:Group >
      <s:DataGrid dataProvider="{model.errorArray}" width="100%" showDataTips="false">
      <s:columns>
      <s:ArrayList>
      <s:GridColumn dataField="name" headerText="Typ" />
      <s:GridColumn id="fStr" dataField="faultString" headerText="Beschreibung" width="255" showDataTips="true" />
      <s:GridColumn dataField="faultCode" headerText="Nummer" />
      </s:ArrayList>
      </s:columns>
      </s:DataGrid>
      </s:Group>
      </s:Scroller>
      The Problem is the ShowDatatip. For the second column, the tooltip works fine. Also column 1 and 3 has the right behavior, no tip.
      But when I click on the button that opens the Popup, in the middle of the DatagritHeader I can see a Tooltip with the label "data Tip" in arrow brackets.
      Where does it come from? How can i suspress this?
      If you need more code, let me know that.
      BR Frank
