• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Struct of Structs
New Here ,
May 27, 2008 May 27, 2008
I build a struct with an entry for each URL on my website. Each entry is a struct that contains some information about that URL. The code that builds this query takes about 5 seconds to run, which is reasonable considering there are 1000's of links.
During the time the code runs, the CPU hovers at about 75% - 95%. I noticed though, that after the request ends and i get back my message saying its finished, the CPU remains high for the next couple of minutes. After that it settles down again. Why would I see that behavior? Is there some processing ColdFusion is doing behind the scenes with the structures?
If there is, how do I know when that processing is finished? The structure created is an application scope structure, so there is a lock around the creation of the struct. However, it does not seem like processing is done when the lock releases.
And it seems like requests that run during that extended processing times are getting ColdFusion errors that look like this "Element FOUNDRESULT is undefined in URLINFO". I know that the structure URLINFO definitely has an element FOUNDRESULT. might these 2 issues be related?
TOPICS
Advanced techniques
Views
526
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , May 27, 2008 May 27, 2008
> <cffunction name="init">
So the instance of the CFC this is in is in the application scope, yes?
> <cflock name="seoSettingsLock" type="exclusive" timeout="120">
I can see a potential problem here (it depends on the calling code, though,
really)... are you controlling how many requests call this code, eg: by
checking if all this work needs to be done? I would expect that check to
be immediately around the lock. If there's no check, you'll get a bag load
of requests queuing up for up t...
Votes
Translate
Translate
LEGEND ,
Quite possible, especially with the lock, if it is overly aggressive in
what is locked. You may have very well singled threaded your
application at this point creating a bottle neck. In other word no
other requests can run until this request is done creating this
structure. While this is going on, other requests are waiting for their
turn to be processed, but they will only wait for so long, and then
start throwing errors. And so after this request is done processing CF
potentially has a long list of other requests, ones that have not timed
out with an error yet, waiting to process. So it gets right on it,
apparently taking a couple of minutes to catch up with all the held up work.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks Ian,
a couple of points
1. It has to be locked while the struct is being loaded, theres no getting around that. but all the read requests have a timeout of 1 second, and they dont throw an error when timing out. I may have to build my own lock to resolve this issue, as there are many lookups into this struct for each page so a timeout of 1 is too long.
2. It doesnt explain the error i'm getting that an element is missing from the struct when i know its there. i get a dump of the struct when the error occurs, and the element is there.
Votes
Translate
Translate
Report
Report
LEGEND ,
What's the timeout on the lock, and does it throw an exception, or just
keep going regardless?
In fact... possibly post the relevant bits of your code so we can see
what's going on.
Adam
Votes
Translate
Translate
Report
Report
New Here ,
here is some of the code
Votes
Translate
Translate
Report
Report
LEGEND ,
of requests queuing up for up to two minutes for this lock to clear. In
the mean time if the lock clears, then another request will start
reprocessing the code within the lock. Surely you don't want that to
happen.
> <cfloop query="getURLs">
> <cfset urlInfo = structNew()>
> <cfset linkInfo.URL = url>
> <cfset linkInfo.pageTitle = pageTitle>
If this code is in a CFC instance that's in the application scope, you have
a potential ptoblem here in that your not VARing any of your variables, so
they're global to the [shared] CFC instance, not local to the function. I
can't see how this would directly cause what you're seeing, but it is
generally an open door for "unexpected behaviour".
If you intend these variables to be in the CFC's variables scope, not local
to the function, can I recommend you always scope them, to make it clearer.
If you had said "variables.urlInfo" I'd surmise you meant it to be in the
variables scope, not just putting it there by accident.
> <cfset structInsert(this.urlsByStatic, staticURL, linkInfo)>
Do you really mean to be putting that in the THIS scope? IE: public to the
calling code? I'm not quite sure what you're exposing here, as this
variable doesn't seem to match the similar-named this.urls you use
elsewhere.
> <cfset info = "">
I'm running on the notion that the CFC instance is in application scope.
So all calls to this method will be sharing this "info" variable.
One call to it could be setting it to ""...
> <cfif structKeyExists(this.urls, keyURL)>
> <cfset info = this.urls["#keyURL#"]>
... whilst another request is here.
> <cfset info.foundResult = true>
So by the time the line above gets executed, info is "", not the value you
were hoping it to be, by setting it on the line above.
This is probably the cause of your problem.
Adam
Votes
Translate
Translate
Report
Report
New Here ,
Yes, its stored in the application scope. The init code should not be running very often at all, and i cant have the init code running from 2 requests at the same time, so that lock is needed.
quote:
If this code is in a CFC instance that's in the application scope, you have ...
The variables should be local to the function. Not varing them was a mistake. As you say, its hard to predict the effect it may have.
Yes. the line of code is wrong, it should read
<cfset structInsert(this.urls, url, linkInfo)>
Reading what you wrote, certainly sounds like a possible source of the problem. I will fix the code and let you know how that works out.
Thanks Adam!
Votes
Translate
Translate
Report
Report
New Here ,
May 28, 2008 May 28, 2008
LATEST
Yup, that did the trick, Adam. Thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
I don't see any reason for the locks. I think it's sufficient to call the functions (without locks) in the correct order.
Votes
Translate
Translate
Report
Report
New Here ,
you are probably right, BKBK. the reason i added the locks is because i was getting that error i posted. however, the locking hasn't fixed it.
any ideas what would cause that error?
Votes
Translate
Translate
Report
Report
New Here ,
Im not 100% sure of what you are trying to achieve but can you not just store the query created in the init function within the application scope and then use the URLinfo function to look at that query (and add/update as needed)?
Does this need to be a struct of structs when you can treat the query as one big structure anyway?
Votes
Translate
Translate
Report
Report
Resources
Documentation
