1. Re: Looking to create a circle with these exact measurements please
simpson246 Dec 22, 2011 7:46 AM (in response to simpson246)EDIT
I meant 2.086614 inches.
2. Re: Looking to create a circle with these exact measurements please
Steve Fairbairn Dec 22, 2011 7:48 AM (in response to simpson246)Option-click with the Ellipse tool and you can enter any measurement you like.
3. Re: Looking to create a circle with these exact measurements please
simpson246 Dec 22, 2011 8:02 AM (in response to simpson246)Thanks for the reply.
I actually figured out another way in the transform option, simply changed the width and height in there to 52.99mm. Sorted.
Quick little question,
im now looking to put little square tags on the top, bottom, left and right.
Need to be the same size as each other, roughly a cm long, 3/4mm wide.
Needs to be attached to the circlebut nothing on the inside of the circle.Whats the best way to do this please.
Many thanks,
4. Re: Looking to create a circle with these exact measurements please
simpson246 Dec 22, 2011 8:05 AM (in response to simpson246)ive currently added the 4 squares on each side, now just need to join them to the circle.
Help please.
5. Re: Looking to create a circle with these exact measurements please
simpson246 Dec 22, 2011 8:29 AM (in response to simpson246)Dont worry all, Solved it with the merge button!
Cheers!
6. Re: Looking to create a circle with these exact measurements please
Steve Fairbairn Dec 22, 2011 8:34 AM (in response to simpson246)Join? You mean group? Or do you mean unite them with the circle? Use Pathfinder panel for this kind of work.
7. Re: Looking to create a circle with these exact measurements please
simpson246 Dec 22, 2011 10:23 AM (in response to simpson246)Thank you.
I simply made the circle the right size,added the squares with a little overlap then merged them.
