• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Removing Read-only
New Here ,
Dec 22, 2011 Dec 22, 2011
How can I create my PDF document from my read-only PDF? Using acrobat or Distiller. I saved the previous doc as Post Script
and ran it throught the distiller. But it still givers me a little blue box, read-only.
Views
24.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
If the pdf is password protected you cannot remove it by redistilling. You need the password to remove the password.
Votes
Translate
Translate
Report
Report
New Here ,
To: Mike
Its no password. This is a 2001 file I created on the distiller. I can save this file and distill it all day, but I need to know what I am doing wrong.
I need to get the blue read-only box on the top of the file removed. acrobat X
thx greg
Votes
Translate
Translate
Report
Report
LEGEND ,
Have you checked the security settings to be sure there is no security set? If you are trying to distill it to the same file, it could be it is opened in Acrobat and so you can not overwrite it or that the original file is read-only in the OS. Look at the file properties in that case. If you are trying to use a network drive, try sending it locally and then copying.
Votes
Translate
Translate
Report
Report
Community Expert ,
Can you post a screenshot of the read-only box?
Votes
Translate
Translate
Report
Report
New Here ,
Dec 23, 2011 Dec 23, 2011
LATEST
I don't have a screen camera, but have figured it out.The original word conversion was 2005 compliant. If you check this box you stuck with a file
that has this paticular drop-down.
Votes
Translate
Translate
Report
Report
LEGEND ,
If it's blue, it will be the box indicating the file is being displayed in PDF/A vew mode.
To temporarily hide the box for all documents, go to Preferences > Documents and set PDF/A view mode to "never" - but you should set it back again after you've finished working with the document.
To remove the PDF/A header information from this particular file, you should run the Acrobat Preflight fixup of that name. There's an Acrobat X Action at AcrobatUsers to automate it.
Votes
Translate
Translate
Report
Report
LEGEND ,
If you created the file, then why not go back to the application you used and recreate it.
Votes
Translate
Translate
Report
Report
