0 Replies Latest reply on May 27, 2008 5:06 PM by bcyde
    Problems Loading Flex swf into Flash swf
    bcyde
      Does anyone have issues with loading a Flex generated .swf into a normal Flash .swf in a non-trivial example?
      I have a customized flex datagrid type app that accesses some web services to populate the grid that is loaded by a shell swf that does a bunch of stuff on its own. The flex swf is only on component of a much larger application.
      We've seen some flakiness where even after getting the returned data from the web service calls the datagrid does not update. When I run the flex swf outside of the shell everything runs fine, however it's just when loaded by the shell that things go awry.
      I've seen this article http://seeing-is-believing.blogspot.com/2007/11/flex-components-in-flash-example-with.html and the comment at the end seems to lead me to believe that flex loaded into a normal flash swf isn't all that stable. Just wondering if anyone else has had these issues and overcome them.
      Thanks for any input.
