0 Replies Latest reply on Dec 23, 2011 2:36 AM by Marauder64r
    Problem with .onPeerConnect
    Marauder64r
      Hi! I have a problem with .onpeerconnect, it's fired only one time. For example, I connect first user, then second, onpeerconnect fired, and I have two users connected, then I connect third user, and onpeerconnect fired only for second user. If I connect fourth user onpeerconnect fired for third, also another problem: when somebody disconnected I have not one but two fired events "NetStream.Connect.Closed". Why does it's all heappen?
      Here is my source:
      import flash.events.NetStatusEvent;
      import flash.media.Camera;
      import flash.media.Microphone;
      import flash.net.NetConnection;
      import flash.net.NetStream;
      import mx.collections.ArrayCollection;
      import mx.controls.Alert;
      public var c:Camera;
      public var outgoingstream:NetStream;
      public var incomingstream:NetStream;
      [Bindable]
      public var myPeerID:String;
      public var ip:String;
      [Bindable]
      private var countuser:int;
      private const CIRRUS_ADDR:String = "rtmfp://p2p.rtmfp.net/";
      private const DEVELOPER_KEY:String = "6dd5260c9c1f5d29328241af-3339d1bd7ff5";
      public var nc:NetConnection;
      //public var farPeerID:String;
      public function cirrusconnect():void {
                nc = new NetConnection;
                nc.maxPeerConnections = 6;
                nc.addEventListener(NetStatusEvent.NET_STATUS, netHandler);
                nc.connect(CIRRUS_ADDR+DEVELOPER_KEY);
      private function netHandler(event: NetStatusEvent):void{
                switch(event.info.code){
                          case "NetConnection.Connect.Success":
                                    myPeerID = nc.nearID
                                    wID.send();
                                    sendstream();
                                    break;
                          case "NetConnection.Connect.Failed":
                                    Alert.show('Connection error');
                                    break;
                          case "NetStream.Connect.Success":
                                    //Alert.show('шлем поток');
                                    break;
                          case "NetStream.Publish.Start":
                                    break;
                          case "NetStream.Connect.Closed":
                          var obj:Object = findObjectByAttribute(users, "stream", event.info.stream);
                                    if(obj == null){
                                    }else{
                                              closestream(event.info.stream);
                                    break;
      private function sendstream():void{ // только для сервера
                outgoingstream = new NetStream (nc, NetStream.DIRECT_CONNECTIONS);
                var camera:Camera = Camera.getCamera();
                camera.setMode(640,480,40);
                camera.setQuality(0,60);
                var mic:Microphone = Microphone.getMicrophone();
                outgoingstream.attachAudio(mic);
                outgoingstream.attachCamera(camera);
                outgoingstream.publish('media');
                var client: Object = new Object();
                client.onPeerConnect =
                          function(callerNS:NetStream):Boolean {
                                    var sendobj:Object = new Object;
                                    sendobj.name = username;
                                    sendobj.rating = rating;
                                    sendobj.id = myPeerID;
                                    callerNS.send('hello', sendobj);
                                    connectcheck(callerNS.farID);
                                    return true;
                outgoingstream.client = client;
      private function connectcheck(id:String):void{
                var i:int = usersid.getItemIndex(id);
                if (i == -1){
                          usersid.addItem(id);
                          connectnew(id);
      private function connectnew(farPeerID:String):void{
                countuser++
                incomingstream = new NetStream(nc, farPeerID);
                incomingstream.play("media");
                var o:Object = new Object();
                o.hello = function(obj:Object):void {
                          if(obj.id == incomingstream.farID){
                                    users.addItem(
                                              {name:obj.name, rating:obj.rating, stream:incomingstream, id:incomingstream.farID})
                                    users.refresh()
                                    if(seating == false){
                                              playerinit();
                                              seating = true; //Убрать ситинг при уходе из комнаты
                incomingstream.client = o;
      private function closestream(exitstream:NetStream):void{
                countuser--
                exitstream.close();
                usersid.removeItemAt(usersid.getItemIndex(exitstream.farID));
                var str:Object = findObjectByAttribute(users, "stream", exitstream);
                users.removeItemAt(users.getItemIndex(str));
                usersid.refresh();
                users.refresh();
      private function findObjectByAttribute(arrayCollection:ArrayCollection,
        attributeName:String, value:NetStream):Object{
                for each (var object:Object in arrayCollection) {
                          if(object[attributeName]==value){
                                    return object;
                return null;
      Thanx!
