0 Replies Latest reply on Dec 23, 2011 9:28 AM by nnmmooppqq
    Printing problem: extra space
    nnmmooppqq
      I am using a print renderer to print out list element. On a seemingly random basis (I can't figure out the pattern), either an entire line or part of a line is indented. E.g., the list print will show:
      2. Text for list item 2            [radio buttons aligned correctly]
      3.      Text for list item 3       [radio buttons aligned correctly]
      4. Text for list item 4            [radio buttons aligned correctly]
         5. Text for list item 5         [radio buttons aligned correctly]
      In this example, item 3 text is improperly indented, and item 5 number is improperly indented. (I've never seen an example where both the number and the text are improperly indented.
      If I run the app again, the improper indents might be on different lines, but there is always at least 1 (usually the last of 10 items).
      I suspect that the print renderer needs to be re-sized after it is fully created but before being sent to the print queue, but I can't figure out how to do this.
      Please help! Thanks in advance.
      JoAnn
      Code that controls the print job:
      public function printContent():void {//called by contentManager based on click event from main printBtn
                  //setup print job:
                  var printJob:FlexPrintJob = new FlexPrintJob();
                  if (printJob.start()) {
                      //Create instance of printRenderer:
                      var asRenderer:asPrintRenderer = new asPrintRenderer();
                      asRenderer.width=printJob.pageWidth;
                      //Put in Title on PrintRenderer:
                      asRenderer.plTitleString=printTitle.toString();
                      //Add the printRenderer, so that it can pick up a dataprovider
                      this.addChild(asRenderer);
                      asRenderer.doCreate(printDP);
                      //make printRenderer invisible
                      asRenderer.visible=false;
                      printJob.addObject(asRenderer);
                      printJob.send();
                      this.removeChild(asRenderer);
      asPrintRenderer code:
      <mx:VBox xmlns:mx="http://www.adobe.com/2006/mxml" backgroundColor="0xffffff" verticalGap="10"
          horizontalAlign="left" width="90%">
      <mx:Script>
          <![CDATA[
              import mx.controls.*
              import mx.collections.*
              import customComponents.asPrintItem
              public function doCreate(ourData:XMLList):void {
                      head1Text.text=parentDocument.head1;
                      head2Text.text=parentDocument.head2;
                      head3Text.text=parentDocument.head3;
                      for (var n:int=0; n<ourData.length(); n++) {
                          //put in text box:
                          var thisBox:asPrintItem=new asPrintItem();
                          addChild(thisBox);
                          thisBox.dorder.text=ourData[n].optionSign.toString();
                          thisBox.optionTextVal.htmlText=ourData[n].optionText;
                          if (ourData[n].isSelected==1) {thisBox.r1.selected=true};
                          if (ourData[n].isSelected==2) {thisBox.r2.selected=true};
                          if (ourData[n].isSelected==3) {thisBox.r3.selected=true};
      </mx:Script>
          <mx:String id="plTitleString" />
          <mx:Text id="plTitle" htmlText="{plTitleString}" styleName="printHeader"/>
          <mx:HBox id="ptitles" width="100%" horizontalAlign="right"  horizontalGap="0" verticalAlign="bottom" verticalGap="0">
                      <mx:Spacer width="64%" />
                      <mx:HBox id="hrt1" horizontalAlign="center" width="12%" styleName="printSmallI" >
                          <mx:Text id="head1Text" text="first" selectable="false" width="100%" horizontalCenter="true"/>
                      </mx:HBox>
                      <mx:HBox id="hrt2" horizontalAlign="center" width="12%"  styleName="printSmallI">
                          <mx:Text id="head2Text" text="second"  width="100%" horizontalCenter="true"/>
                      </mx:HBox>
                      <mx:HBox id="hrt3" horizontalAlign="center" width="12%" styleName="printSmallI">
                          <mx:Text id="head3Text" text="third"  width="100%" horizontalCenter="true"/>
                      </mx:HBox>
          </mx:HBox>
      </mx:VBox>
      asPrintItem Code:
      <mx:HBox xmlns:mx="http://www.adobe.com/2006/mxml" width="100%" horizontalAlign="left" >
          <mx:Text id="dorder" text="1" width="4%" styleName="printRegular" />
          <mx:Text id="optionTextVal" htmlText="Here is item" selectable="false" width="60%" styleName="printRegular"/>
              <mx:HBox id="hr1" horizontalAlign="center" width="12%"  >
                  <mx:RadioButton id="r1" groupName="g" />
              </mx:HBox>
              <mx:HBox id="hr2" horizontalAlign="center" width="12%"  >
                  <mx:RadioButton id="r2" groupName="g" />
              </mx:HBox>
              <mx:HBox id="hr3" horizontalAlign="center" width="12%" >
                  <mx:RadioButton id="r3" groupName="g" />
              </mx:HBox>
      </mx:HBox>
