1. Re: Chart problem...
Silkrooster Dec 23, 2011 9:13 PM (in response to HSGROW_HK)Use the pie style chart then fill the center using the elipse tool with what ever color you like. To change the fill colors of the pie itself, expand its appearence then ungroup. Once that is done you can no longer using the spreadsheet to edit the values.
2. Re: Chart problem...
Steve Fairbairn Dec 24, 2011 2:33 AM (in response to Silkrooster)You definitely do NOT need to ungroup to recolour graphs.
Direct select works perfectly well on graphs.
Bear in mind though that grouping within graphs is sometimes complex, so if you have legends and stuff you may need to option-click to select whole groups within the graph.
But a simple chart like this should present no problems.
3. Re: Chart problem...
HSGROW_HK Dec 25, 2011 8:46 PM (in response to Steve Fairbairn)So that helps, how do I create the labels & values in that circular style and align nicely with the individual wedge, as shown in the picture?
4. Re: Chart problem...
Steve Fairbairn Dec 26, 2011 3:52 AM (in response to HSGROW_HK)Probably manually.
5. Re: Chart problem...
JETalmage Dec 26, 2011 5:20 AM (in response to HSGROW_HK)...how do I create the labels & values in that circular style and align nicely with the individual wedge, as shown in the picture?
Won't happen automatically. Setting the option for Legends In Wedges will cause the text objects to appear in the wedges, and you can directSelect them (white pointer) to move them to where you want them. But they will snap back to inside the wedges if you update the data. Also, they will display only text values from your first-row of data, not numerical values. You can't make the pie graph auto-display text objects containing both the values and the titles as in your example.
JET
