3 Replies Latest reply: Dec 24, 2011 8:35 AM by kglad RSS
    Navigating using a loader script and how to modify script to use labels instead of frame numbers?
    marisol_Q Community Member
      Hello,
      This is my first Flash portfolio, so please bear with me. I have 4 layers: Home (frames 1-19); images and navigation buttons (frames 20-40) that contains a loader with 10 sub-layers, click a button and user navigates to separate and distinct clips; and experience (frames 41-60). If I use the script below, will it work properly? I added stops in the script because if I didn't, I would get endless looping between frames.
      And, how do I modify script below to say: home instead of frame 1? And, if I want to add a hyperlink mailto:, how do I add a subject line and a bcc address? I selected my email, highlighted it and enter the mailto: line, with target as _blank
      Thanks very much.
      stop();
      import flash.display.Loader;
      import flash.events.MouseEvent;
      import flash.net.URLRequest;
      var myLoader:Loader = new Loader();
      swf1.addEventListener(MouseEvent.CLICK, loadMySWF);
      swf2.addEventListener(MouseEvent.CLICK, loadMySWF);
      swf3.addEventListener(MouseEvent.CLICK, loadMySWF);
      swf4.addEventListener(MouseEvent.CLICK, loadMySWF);
      swf5.addEventListener(MouseEvent.CLICK, loadMySWF);
      swf6.addEventListener(MouseEvent.CLICK, loadMySWF);
      swf7.addEventListener(MouseEvent.CLICK, loadMySWF);
      swf8.addEventListener(MouseEvent.CLICK, loadMySWF);
      function loadMySWF(event:MouseEvent):void{
          var newPage:URLRequest = new URLRequest(event.target.name +".swf");
          myLoader.load(newPage);
          addChild(myLoader);
      stop();
      home_btn.addEventListener(MouseEvent.CLICK, fl_ClickToGoToAndStopAtFrame_1);
      function fl_ClickToGoToAndStopAtFrame_1(event:MouseEvent):void
          gotoAndStop(1);
      stop();
      experience_btn.addEventListener(MouseEvent.CLICK, fl_ClickToGoToAndStopAtFrame_41);
      function fl_ClickToGoToAndStopAtFrame_41(event:MouseEvent):void
          gotoAndStop(41);
      stop();
        • 1. Re: Navigating using a loader script and how to modify script to use labels instead of frame numbers?
          kglad CommunityMVP
          stop();
              addChild(myLoader);
          stop();
              gotoAndStop("home");
          stop();
              gotoAndStop(41);
          stop();
          user's default email program (if they have one):
          navigateToURL(new URLRequest("mailto:somebody@anywhere.com?cc=cc@anywhere.com&bcc=bcc@anywhere.com&subject=I am the email subject&body=I am the email body"));
          • 2. Re: Navigating using a loader script and how to modify script to use labels instead of frame numbers?
            Thanks. I feel more confident now that you've reviewed my script. Final question to clarify. Is this how I would use the label instead of a frame number?
            stop();
            home_btn.addEventListener(MouseEvent.CLICK, fl_ClickToGoToAndStop"home");
            function fl_ClickToGoToAndStopAt"home"(event:MouseEvent):void
            • 3. Re: Navigating using a loader script and how to modify script to use labels instead of frame numbers?
              kglad CommunityMVP
              no, just use the code i suggested.  you're getting confused by a function name:
              // this
              // works the same as
              home_btn.addEventListener(MouseEvent.CLICK, f);
              function f(event:MouseEvent):void
              // use any function name you find helpful (and that hasn't been used before)
