I borrowed a book from my library's online eBook selection and successfully got it to ADE. After that I finally got it to my NOOK. Then when I opened it it said: Error Dialog User not activated. Is it because either my computer or NOOK is not authorized? If so I already authorized by computer and I'm not sure about my NOOK but it does show up in ADE. Please help!
I have the same problem!!
This worked for a lot of people (sadly not me) and maybe it will work for you:
If that doesn't work , try this (it has a few more extra steps)
1) plug in your nook via USB and delete the digital editions folders.
2) properly eject and unplug your nook from your computer.
3) uninstall ADE and then reinstall ADE from the website (surprise! there is a 2.0 version out there...this is the underlying issue, i think)
4) delete any library books from ADE but don't return them (right click on the books and say remove from library don't use the return feature. if you return them, you'll have to reborrow. deleting them doesn't do anything except dissassociate them from ADE. i read somwhere that the next step wipes out the lending info from ADE, so i did this just in case that meant it would return my items. this step may be entirely unnecessary, but better safe than sorry).
5) once you open the new version of ADE, hit control+shift+d. it will ask you if you want to erase your previous authorization FOR YOUR COMPUTER. you do, so say yes. once you remove your previous authorization for your computer, then go to help...authorize computer. put in your adobeID information. this will reauthorize your computer to use ADE.
6) plug in your nook via USB. once you see it appear in the ADE bookshelves, clik on the little gear icon (settings) and click on authorizedevice. it'll reauthorize your nook with the new nook software version andthe new ADE software version.
7) redownload your library books (if you followed step 4) and transfer them to your nook as usual.
