4 Replies Latest reply on Jan 3, 2012 3:00 AM by Flex4_5
    parsing xml
    Flex4_5
      Hi ALL:
      when i run my application i have this message i can't retrieve solution
      TypeError: Error #1088:The marking of the document after the root element must be made correctly.
      at mx.utils::XMLNotifier/watchXML()[E:\dev\hero_private\frameworks\projects\framework\src\mx \utils\XMLNotifier.as:158]
                at mx.binding::XMLWatcher/updateParent()[E:\dev\hero_private\frameworks\projects\framework\s rc\mx\binding\XMLWatcher.as:125]
                at mx.binding::Watcher/addChild()[E:\dev\hero_private\frameworks\projects\framework\src\mx\b inding\Watcher.as:107]
                at _workflowmonitorWatcherSetupUtil/setup()
                at workflowmonitor()[E:\IndegoPredict\P_WorkFlowMonitor\src\workflowmonitor.mxml:120]
                at _workflowmonitor_mx_managers_SystemManager/create()[_workflowmonitor_mx_managers_SystemMa nager.as:53]
                at mx.managers.systemClasses::ChildManager/initializeTopLevelWindow()[E:\dev\hero_private\fr ameworks\projects\framework\src\mx\managers\systemClasses\ChildManager.as:311]
                at mx.managers::SystemManager/initializeTopLevelWindow()[E:\dev\hero_private\frameworks\proj ects\framework\src\mx\managers\SystemManager.as:3063]
                at mx.managers::SystemManager/http://www.adobe.com/2006/flex/mx/internal::kickOff()[E:\dev\hero_private\frameworks\projects\framework\src\mx\managers\SystemManager.as:2849 ]
                at mx.managers::SystemManager/http://www.adobe.com/2006/flex/mx/internal::preloader_completeHandler()[E:\dev\hero_private\frameworks\projects\framework\src\mx\managers\SystemManager.as:2729 ]
                at flash.events::EventDispatcher/dispatchEventFunction()
                at flash.events::EventDispatcher/dispatchEvent()
                at mx.preloaders::Preloader/timerHandler()[E:\dev\hero_private\frameworks\projects\framework \src\mx\preloaders\Preloader.as:542]
                at flash.utils::Timer/_timerDispatch()
                at flash.utils::Timer/tick()
      please help me
      thanks in advance
        • 1. Re: parsing xml
          Claudiu Ursica Level 4
          Is your XML coming from the server? If so make sure is correctly formatted and no null value are send over, that might fix it.
          C
          • 2. Re: parsing xml
            Flex4_5 Level 1
            thks Claudiu:
            I'm sure my xml is correctly formating because it works well with flex 3
            I test my project in offline mode and i add the path xml to file mxml but this error still appeared
            • 3. Re: parsing xml
              can you sreamline it with a small example and the xml, something one ca debug?
              C
              • 4. Re: parsing xml
                Flex4_5 Level 1
                <?xml version="1.0" encoding="UTF-8" ?>
                <workflowmonitor databuilding="false" refresh="30" currencythreshold="true" servertime="2008-10-01T10:05:22" servertimezone="0" lastRefTime="10:05 (+00:00)" entityoffset="+00:00">
                  <request_reply>
                    <status_ok>true</status_ok>
                    <message>Data fetch ok</message>
                    <location/>
                  </request_reply>
                  <timing>
                    <operation id="all">953</operation>
                  </timing>
                  <movementsummary>
                    <movements name="Unsettled Yesterday" id="unsettledyesterday">0.0</movements>
                    <movements name="Open Unexpected" id="openunexpected">0.0</movements>
                    <movements name="Back Valued" id="backvalued">6262.0</movements>
                  </movementsummary>
                  <inputsummary>
                    <input name="Input Exceptions" id="inputexceptions">778.0</input>
                    <input name="Input Authorise (All days)" id="inputauthorise">0.0</input>
                    <input name="Input Referred (All days)" id="inputreffered">0.0</input>
                  </inputsummary>
                  <matchessummary>
                    <matches name="Offered Matches" id="offeredmatches">0.0</matches>
                    <matches name="Suspended Matches" id="suspendedmatches">0.0</matches>
                    <matches name="Confirmed Matches" id="confirmedmatches">0.0</matches>
                    <matches name="Offered Matches sub" id="offeredmatchessub">0.0</matches>
                    <matches name="Suspended Matches Sub" id="suspendedmatchessub">0.0</matches>
                    <matches name="Confirmed Matches Sub" id="confirmedmatchessub">0.0</matches>
                  </matchessummary>
                  <sweepssummary>
                    <sweeps name="Submit Sweeps" id="submitsweeps">0.0</sweeps>
                    <sweeps name="Authorise Sweeps" id="authorisesweeps">0.0</sweeps>
                    <sweeps name="Nak Sweeps" id="naksweeps">0.0</sweeps>
                  </sweepssummary>
                  <systemsummary>
                    <system name="Logged on Users" id="loggedonusers">1</system>
                    <system name="Error Log" id="errorlog">21.0</system>
                  </systemsummary>
                  <positions includedtotal="4259" excludedtotal="225">
                    <position num="1" level="Kondor+" included="0" excluded="0"/>
                    <position num="2" level="Pre-advices" included="0" excluded="0"/>
                    <position num="3" level="Back Office" included="3500" excluded="0"/>
                    <position num="4" level=""/>
                    <position num="5" level=""/>
                    <position num="6" level="Atlas" included="392" excluded="98"/>
                    <position num="7" level="SWIFT" included="0" excluded="0"/>
                    <position num="8" level="SWIFT - Final" included="367" excluded="127"/>
                    <position num="9" level=""/>
                    <position num="10" level="Reconciled" included="0" excluded=""/>
                  </positions>
                  <selects>
                    <select id="entity">
                      <option value="All" selected="0">All</option>
                      <option value="RABONL2U" selected="1">Rabobank Utrecht</option>
                      <option value="ING4" selected="0">INGBYKAIS</option>
                      <option value="INGBNL8A" selected="0">Chams Entity</option>
                      <option value="ING5" selected="0">ING5</option>
                      <option value="ING9" selected="0">ING9</option>
                      <option value="ING2" selected="0">ING2</option>
                      <option value="ING3" selected="0">ING3</option>
                      <option value="ING1" selected="0">ING1 by Saber</option>
                      <option value="ING6" selected="0">ING6</option>
                      <option value="TEST" selected="0">test</option>
                      <option value="RABOUS33" selected="0">Rabobank New York</option>
                      <option value="Mnts13Entity" selected="0">Entity for Mantis 13</option>
                    </select>
                    <select id="currency">
                      <option value="All" selected="1">All</option>
                      <option value="ASIA-PACIFIC" selected="0">Asia-Pacific Currencies</option>
                      <option value="CAD" selected="0">Canadian Dollars</option>
                      <option value="CHF" selected="0">Swiss Francs</option>
                      <option value="EAST EUROPE" selected="0">Eastern European Currencies</option>
                      <option value="EMERGING" selected="0">Emerging Markets</option>
                      <option value="EUR" selected="0">Euros</option>
                      <option value="GBP" selected="0">Pounds Sterling</option>
                      <option value="SCANDIES" selected="0">Scandinavian Currencies</option>
                      <option value="USD" selected="0">US Dollars</option>
                    </select>
                  </selects>
                  <tabs>
                    <predictdate businessday="true">01/10/2008</predictdate>
                    <predictdate businessday="true">02/10/2008</predictdate>
                    <predictdate businessday="true">03/10/2008</predictdate>
                    <predictdate businessday="false">04/10/2008</predictdate>
                    <predictdate businessday="false">05/10/2008</predictdate>
                    <predictdate businessday="true">06/10/2008</predictdate>
                    <predictdate businessday="true">07/10/2008</predictdate>
                    <selectedIndex index="0"/>
                  </tabs>
                </workflowmonitor>
