3 Replies Latest reply on Jan 8, 2012 3:59 PM by ElsHiro
    how to export portions of a sequence for usage in future projects
    ElsHiro
      Hello guys,
      I was wondering if you could help me with this.
      I just finished a first episode of a documentary series. I need to use the opening and closing of this first episode for future episodes.
      Could you please kindly tell me how I should go about saving/exporting the opening & closing portion of the sequence as a separate file so that i can use it or import it into future projects of the documentary series.
      Both the opening and closing contain photo images, videos and audios including the soundtrack - they represent my jingle and more, so i dont want to lose anything while exporting it
      I use premiere pro CS5.5 which i bought 3 weeks ago, so i am still very much a learner.
      Any suggestions would be very appreciated.
      Many thanks
        • 1. Re: how to export portions of a sequence for usage in future projects
          Stephen_Spider Level 3
          When I finish the first in a series or want to save graphic elements for future use, I save the project under a new name. Then I de-construct the project, deleting from the project all the assets that won't be used again in the future. I clean and organize the sequences and bins, then use Project Manager to create a new self contained  "trimmed" project in a new folder. It is usually named something like "Project X TEMPLATE". The project Manager can copy all of the assets to the new Project X TEMPLATE folder.
          So when it is time to do "Project X episode 2", I create a new folder for it, then open the "Project X TEMPLATE" and then immediately save the project as "Project X episode 2" in the "Project X episode 2" folder. That way the Template project is never changed, and each project going forward will be self contained in one folder that I can back up or deleted without fouling up any other projects.
          It may also be a good idea to back up the whole""Project X Template" folder to a data disc, either DVD-R or Blu-ray.
          You can also save some graphic sequences to an Uncompressed codec (with Alpha Channel if needed), or something like the Lagarith lossless codec, which can be downloaded for free.
          • 2. Re: how to export portions of a sequence for usage in future projects
            ElsHiro Level 1
            That's awesome Stephen! will try that straight away and keep you posted.
            Thanks loads
            • 3. Re: how to export portions of a sequence for usage in future projects
              ElsHiro Level 1
              Hello Stephen, just a quick note to say thanks again. Your answer was really spot-on!
              Cheers.
