• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
XML value not reading correctly
Enthusiast ,
Dec 26, 2011 Dec 26, 2011
I am trying to read an XML response after passing data to a 3rd party server and receiving a reply then act appropriately upon the value of a field (response)
The problem is that when I have my CFIF statement, the logic seems to be backwards, if it equals FAIL then I cfabort, but only if I use CFIF NOT does it then cfabort, this is not right at all
As the code stands, the CFIF the value of response IS fail it should CFABORT, but it doesn't
Below is the code, and also a CFDUMP, anybody any ideas?
Mark
xml document [short version]
XmlComment
XmlRoot
xml element
XmlNameiimobileengine
XmlNsPrefix
XmlNsURI
XmlText
XmlComment
XmlAttributes
struct [empty]
XmlChildren
xml element
XmlNamestage
XmlNsPrefix
XmlNsURI
XmlTextPRELOAD
XmlComment
XmlAttributes
struct [empty]
XmlChildren
xml element
XmlNameresponse
XmlNsPrefix
XmlNsURI
XmlTextFAIL
XmlComment
XmlAttributes
struct [empty]
XmlChildren
xml element
XmlNamelid
XmlNsPrefix
XmlNsURI
XmlText
XmlComment
XmlAttributes
struct [empty]
XmlChildren
xml element
XmlNamelsdid
XmlNsPrefix
XmlNsURI
XmlText
XmlComment
XmlAttributes
struct [empty]
XmlChildren
xml element
XmlNamereason
XmlNsPrefix
XmlNsURI
XmlTextCarrier Not Supported
XmlComment
XmlAttributes
struct [empty]
XmlChildren
xml element
XmlNametc
XmlNsPrefix
XmlNsURI
XmlText
XmlComment
XmlAttributes
struct [empty]
XmlChildren
iimobileengine
XmlText
stage
XmlTextPRELOAD
response
XmlTextFAIL
lid
XmlText
lsdid
XmlText
reason
tc
XmlText
<cfset myxml=XMLParse(#cfhttp.filecontent#)>
<CFDUMP VAR="#myxml#">
        <!--- CHECK FOR FAIL RESPONSE --->
<CFIF #myxml.iimobileengine.response# IS "FAIL">
<CFOUTPUT>Stage 1: #myxml.iimobileengine.reason#</CFOUTPUT>
<CFABORT>
</CFIF>
TOPICS
Advanced techniques
Views
1.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Isn't "response" an element? If so, what happens when you reference myxml.iimobileengine.response.XmlText (the text node within your response element) instead of referencing the element (which is not a string) directly?
Dave Watts, CTO, Fig Leaf Software
Votes
Translate
Translate
Report
Report
Enthusiast ,
Hey Dave, it works, THANKS!
I have never worked with reading XML's before so I found it a little confusing.
The thing that threw me and still does is that if I CFOUTPUT #myxml.iimobileengine.response# without the XMLText part, then it does display FAIL, yet doesnt read it in a logic CFIF statement..strange (well strange to me right now
Mark
Votes
Translate
Translate
Report
Report
Community Expert ,
Well, working with XML in CF is kind of strange. CF generally makes it much easier, but as a result it can be difficult to figure out how something should act when you're working with XML in CF.
In this case, when you output the element, it outputs all the text nodes within the element, but that doesn't mean that the text node value is equivalent to the element. For example, let's say you had an XML fragment like this:
<tag1>some text
     <tag2>some more text</tag2>
     still more text</tag1>
When you output that with CF, I would expect you'd either get:
some text
some more text
still more text
or:
some text
still more text
(I can't be bothered to test)
But the point is that a single XML element can have all sorts of things in it, including multiple text nodes.
Votes
Translate
Translate
Report
Report
Enthusiast ,
I am going to try avoid this as much as possible! Too confusing!
Looks like in this case I can/should add XMLText to the end of all of my statements including output of results
Votes
Translate
Translate
Report
Report
Community Expert ,
Dec 29, 2011 Dec 29, 2011
LATEST
The fact that it can work without XmlText is down to luck. That, I suppose, is also what Dave means. ColdFusion is forgiving you. In fact, your coming here with the problem is warning enough.
Your code should, strictly speaking, be something like:
<CFIF myxml.iimobileengine.response.XmlText IS "FAIL">
<CFOUTPUT>Stage 1: #myxml.iimobileengine.reason.XmlText#</CFOUTPUT>
<CFABORT>
</CFIF>
To see why adding XmlText is a good habit, run the following test:
isXml(myxml.iimobileengine.response): <cfoutput>#isXml(myxml.iimobileengine.response)#</cfoutput><br>
<cfdump var="#myxml.iimobileengine.response#">
It should convince you that myxml.iimobileengine.response isn't just simple text.
Votes
Translate
Translate
Report
Report
Enthusiast ,
I just went back and double checked and sure enough they both OUTPUT the same but only one of them actually works within a logic statement, so that can be rather confusing and open to potential coding errors
This code, gives
FAIL
FAIL
<CFOUTPUT>
<br>
#myxml.iimobileengine.response.XmlText#
</CFOUTPUT>
Votes
Translate
Translate
Report
Report
Resources
Documentation
