1 Reply Latest reply on Dec 27, 2011 12:13 AM by Paul Riggott
    Saveas Scripting help request
    IvenBach
      I am trying to piece together a maro that will initially resize an image and save it with a different suffix at different size increments. I found within the cs5 scripts folder the macro 'Fit Image.jsx' that would allow me to resize correctly but am lost on how to add in the subsequent save steps and additional resize and saves. I would like to have it save the image with 5 different file sizes and suffixes (400x400 '-2' suffix, 250x250 '-2T', 150x150 '-1', 100x100 '-0', and 50x50 '-2S'). I found some information on the saveas http://forums.adobe.com/message/2652204 but have no experience with javascript. I have some understanding of VBA and believe a loop could be used but haven't the slightest idea how to set this up. Is there anyone out there that could help walk me through this and lend me a hand?
      ---Below contains the 'Fit Image.jsx' file that I found---
      // c2008 Adobe Systems, Inc. All rights reserved.
      // Written by Ed Rose
      // based on the ADM Fit Image by Charles A. McBrian from 1997
      // edited by Mike Hale added option to avoid resize on images already smaller than target size
      @@@BUILDINFO@@@ Fit Image.jsx 1.0.0.21
      /* Special properties for a JavaScript to enable it to behave like an automation plug-in, the variable name must be exactly
         as the following example and the variables must be defined in the top 1000 characters of the file
      // BEGIN__HARVEST_EXCEPTION_ZSTRING
      <javascriptresource>
      <name>$$$/JavaScripts/FitImage/Name=Fit Image...</name>
      <menu>automate</menu>
      <enableinfo>true</enableinfo>
      <eventid>3caa3434-cb67-11d1-bc43-0060b0a13dc4</eventid>
      <terminology><![CDATA[<< /Version 1
                               /Events <<
                                /3caa3434-cb67-11d1-bc43-0060b0a13dc4 [($$$/AdobePlugin/FitImage/Name=Fit Image) /imageReference <<
                                 /width [($$$/AdobePlugin/FitImage/Width=width) /pixelsUnit]
                                 /height [($$$/AdobePlugin/FitImage/Height=height) /pixelsUnit]
                                 /limit [($$$/AdobePlugin/FitImage/limit=Don't Enlarge) /boolean]
                            >> ]]></terminology>
      </javascriptresource>
      // END__HARVEST_EXCEPTION_ZSTRING
      // enable double clicking from the Macintosh Finder or the Windows Explorer
      #target photoshop
      // debug level: 0-2 (0:disable, 1:break on error, 2:break at beginning)
      // $.level = 2;
      // debugger; // launch debugger on next line
      // on localized builds we pull the $$$/Strings from a .dat file, see documentation for more details
      $.localize = true;
      var isCancelled = true; // assume cancelled until actual resize occurs
      // the main routine
      // the FitImage object does most of the work
      try {
          // create our default params
          var sizeInfo = new SizeInfo();
          GlobalVariables();
          CheckVersion();
          var gIP = new FitImage();
          if ( DialogModes.ALL == app.playbackDisplayDialogs ) {
              gIP.CreateDialog();
              gIP.RunDialog();
          else {
              gIP.InitVariables();
              ResizeTheImage(sizeInfo.width.value, sizeInfo.height.value);
          if (!isCancelled) {
              SaveOffParameters(sizeInfo);
      // Lot's of things can go wrong
      // Give a generic alert and see if they want the details
      catch( e ) {
          if ( DialogModes.NO != app.playbackDisplayDialogs ) {
              alert( e + " : " + e.line );
      // restore the dialog modes
      app.displayDialogs = gSaveDialogMode;
      isCancelled ? 'cancel' : undefined;
      function ResizeTheImage(width, height) {
          var oldPref = app.preferences.rulerUnits;
          var docWidth;
          var docHeight;
          var docRatio;
          var newWidth;
          var newHeight;
          var resolution = app.activeDocument.resolution;
          var limit = sizeInfo.limit;
          app.preferences.rulerUnits = Units.PIXELS; // save old preferences
          // original width, height
          docWidth = (1.0 * app.activeDocument.width * resolution) / 72.0; // decimal inches assuming 72 dpi (used in docRatio)
          docHeight = (1.0 * app.activeDocument.height * resolution) / 72.0; // ditto
          if (docWidth < 1.0 || docHeight < 1.0)
              return true; // error
          if (width < 1 || height < 1)
          if ( limit && ( docWidth <= width && docHeight <= height ) ){
              app.preferences.rulerUnits = oldPref; // restore old prefs
              isCancelled = false; // if get here, definitely executed
              return false; // no error
          docRatio = docWidth / docHeight; // decimal ratio of original width/height
          newWidth = width;
          newHeight = ((1.0 * width) / docRatio); // decimal calc
          if (newHeight > height) {
              newWidth = docRatio * height; // decimal calc
              newHeight = height;
          // resize the image using a good conversion method while keeping the pixel resolution
          // and the aspect ratio the same
          app.activeDocument.resizeImage(newWidth, newHeight, resolution, ResampleMethod.BICUBIC);
      // created in
      function SaveOffParameters(sizeInfo) {
          // save off our last run parameters
          var d = objectToDescriptor(sizeInfo, strMessage);
          app.putCustomOptions("3caa3434-cb67-11d1-bc43-0060b0a13dc4", d);
          app.playbackDisplayDialogs = DialogModes.ALL;
          // save off another copy so Photoshop can track them corectly
          var dd = objectToDescriptor(sizeInfo, strMessage);
          app.playbackParameters = dd;
      function GlobalVariables() {
          // a version for possible expansion issues
          gVersion = 1.1;
          gMaxResize = 300000;
          // remember the dialog modes
          gSaveDialogMode = app.displayDialogs;
          app.displayDialogs = DialogModes.NO;
          gInAlert = false;
          // all the strings that need to be localized
          strTitle = localize( "$$$/JavaScript/FitImage/Title=Fit Image" );
          strConstrainWithin = localize( "$$$/JavaScript/FitImage/ConstrainWithin=Constrain Within" );
          strTextWidth = localize("$$$/JavaScripts/FitImage/Width=&Width:");
          strTextHeight = localize("$$$/JavaScripts/FitImage/Height=&Height:");
          strTextPixels = localize("$$$/JavaScripts/FitImage/Pixels=pixels");
          strButtonOK = localize("$$$/JavaScripts/FitImage/OK=OK");
          strButtonCancel = localize("$$$/JavaScripts/FitImage/Cancel=Cancel");
          strTextSorry = localize("$$$/JavaScripts/FitImage/Sorry=Sorry, Dialog failed");
          strTextInvalidType = localize("$$$/JavaScripts/FitImage/InvalidType=Invalid numeric value");
          strTextInvalidNum = localize("$$$/JavaScripts/FitImage/InvalidNum=A number between 1 and 300000 is required. Closest value inserted.");
          strTextNeedFile = localize("$$$/JavaScripts/FitImage/NeedFile=You must have a file selected before using Fit Image");
          strMessage = localize("$$$/JavaScripts/FitImage/Message=Fit Image action settings");
          strMustUse = localize( "$$$/JavaScripts/ImageProcessor/MustUse=You must use Photoshop CS 2 or later to run this script!" );
          strLimitResize = localize("$$$/JavaScripts/FitImage/Limit=Don^}t Enlarge");
      // the main class
      function FitImage() {
          this.CreateDialog = function() {
              // I will keep most of the important dialog items at the same level
              // and use auto layout
              // use overriding group so OK/Cancel buttons placed to right of panel
              var res =
                  "dialog { \
                      pAndB: Group { orientation: 'row', \
                          info: Panel { orientation: 'column', borderStyle: 'sunken', \
                              text: '" + strConstrainWithin +"', \
                              w: Group { orientation: 'row', alignment: 'right',\
                                  s: StaticText { text:'" + strTextWidth +"' }, \
                                  e: EditText { preferredSize: [70, 20] }, \
                                  p: StaticText { text:'" + strTextPixels + "'} \
                              h: Group { orientation: 'row', alignment: 'right', \
                                  s: StaticText { text:'" + strTextHeight + "' }, \
                              l: Group { orientation: 'row', alignment: 'left', \
                                      c:Checkbox { text: '" + strLimitResize + "', value: false }, \
                          buttons: Group { orientation: 'column', alignment: 'top',  \
                              okBtn: Button { text:'" + strButtonOK +"', properties:{name:'ok'} }, \
                              cancelBtn: Button { text:'" + strButtonCancel + "', properties:{name:'cancel'} } \
              // the following, when placed after e: in w and h doesn't show up
              // this seems to be OK since px is put inside the dialog box
              //p: StaticText { text:'" + strTextPixels + "'}
              // create the main dialog window, this holds all our data
              this.dlgMain = new Window(res,strTitle);
              // create a shortcut for easier typing
              var d = this.dlgMain;
              // match our dialog background color to the host application
              d.graphics.backgroundColor = d.graphics.newBrush (d.graphics.BrushType.THEME_COLOR, "appDialogBackground");
              d.defaultElement = d.pAndB.buttons.okBtn;
              d.cancelElement = d.pAndB.buttons.cancelBtn;
          } // end of CreateDialog
          // initialize variables of dialog
          this.InitVariables = function() {
              // look for last used params via Photoshop registry, getCustomOptions will throw if none exist
              try {
                  var desc = app.getCustomOptions("3caa3434-cb67-11d1-bc43-0060b0a13dc4");
                  descriptorToObject(sizeInfo, desc, strMessage);
              catch(e) {
                  // it's ok if we don't have any options, continue with defaults
              // see if I am getting descriptor parameters
              var fromAction = !!app.playbackParameters.count;
              if( fromAction ){
                  // reset sizeInfo to defaults
                  SizeInfo = new SizeInfo();
                  // set the playback options to sizeInfo
                  descriptorToObject(sizeInfo, app.playbackParameters, strMessage);
              // make sure got parameters before this
              if (app.documents.length <= 0) // count of documents viewed
                      alert(strTextNeedFile); // only put up dialog if permitted
                  return false; // if no docs, always return
              var w = app.activeDocument.width;
              var h = app.activeDocument.height;
              var l = true;
              if (sizeInfo.width.value == 0) {
                  sizeInfo.width = w;
              else {
                  w = sizeInfo.width;
              if (sizeInfo.height.value == 0) {
                  sizeInfo.height = h;
              else {
                  h = sizeInfo.height;
                  d.ip = this;
                  d.pAndB.info.w.e.text = Number(w);
                  d.pAndB.info.h.e.text = Number(h);
                  d.pAndB.info.l.c.value = sizeInfo.limit;
              return true;
          // routine for running the dialog and it's interactions
          this.RunDialog = function () {
              // in case hit cancel button, don't close
              d.pAndB.buttons.cancelBtn.onClick = function() {
                  var dToCancel = FindDialog( this );
                  dToCancel.close( false );
              // nothing for now
              d.onShow = function() {
              // do not allow anything except for numbers 0-9
              d.pAndB.info.w.e.addEventListener ('keydown', NumericEditKeyboardHandler);
              d.pAndB.info.h.e.addEventListener ('keydown', NumericEditKeyboardHandler);
              // hit OK, do resize
              d.pAndB.buttons.okBtn.onClick = function () {
                  if (gInAlert == true) {
                      gInAlert = false;
                      return;
                  var wText = d.pAndB.info.w.e.text;
                  var hText = d.pAndB.info.h.e.text;
                  var lValue = d.pAndB.info.l.c.value;
                  var w = Number(wText);
                  var h = Number(hText);
                  sizeInfo.limit = Boolean(lValue);
                  var inputErr = false;
                  if ( isNaN( w ) || isNaN( h ) ) {
                          alert( strTextInvalidType );
                      if (isNaN( w )) {
                          sizeInfo.width = new UnitValue( 1, "px" );
                          d.pAndB.info.w.e.text = 1;
                      } else {
                          sizeInfo.height = new UnitValue( 1, "px" );
                          d.pAndB.info.h.e.text = 1;
                          return false;
                  else if (w < 1 || w > gMaxResize || h < 1 || h > gMaxResize) {
                          gInAlert = true;
                          alert( strTextInvalidNum );
                  if ( w < 1) {
                      inputErr = true;
                  if ( w > gMaxResize) {
                      inputErr = true;
                      sizeInfo.width = new UnitValue( gMaxResize, "px" );
                      d.pAndB.info.w.e.text = gMaxResize;
                  if ( h < 1) {
                      inputErr = true;
                  if ( h > gMaxResize) {
                      inputErr = true;
                      sizeInfo.height = new UnitValue( gMaxResize, "px" );
                      d.pAndB.info.h.e.text = gMaxResize;
                  if (inputErr == false)  {
                      sizeInfo.width = new UnitValue( w, "px" );
                      sizeInfo.height = new UnitValue( h, "px" );
                      if (ResizeTheImage(w, h)) { // the whole point
                          // error, input or output size too small
                      d.close(true);
                  return;
              if (!this.InitVariables())
                  return true; // handled it
              // give the hosting app the focus before showing the dialog
              app.bringToFront();
              this.dlgMain.center();
              return d.show();
      function CheckVersion() {
          var numberArray = version.split(".");
          if ( numberArray[0] < 9 ) {
                  alert( strMustUse );
              throw( strMustUse );
      function FindDialog( inItem ) {
          var w = inItem;
          while ( 'dialog' != w.type ) {
              if ( undefined == w.parent ) {
                  w = null;
                  break;
              w = w.parent;
          return w;
      // Function: objectToDescriptor
      // Usage: create an ActionDescriptor from a JavaScript Object
      // Input: JavaScript Object (o)
      //        object unique string (s)
      //        Pre process converter (f)
      // Return: ActionDescriptor
      // NOTE: Only boolean, string, number and UnitValue are supported, use a pre processor
      //       to convert (f) other types to one of these forms.
      // REUSE: This routine is used in other scripts. Please update those if you
      //        modify. I am not using include or eval statements as I want these
      //        scripts self contained.
      function objectToDescriptor (o, s, f) {
          if (undefined != f) {
              o = f(o);
          var d = new ActionDescriptor;
          var l = o.reflect.properties.length;
          d.putString( app.charIDToTypeID( 'Msge' ), s );
          for (var i = 0; i < l; i++ ) {
              var k = o.reflect.properties[i].toString();
              if (k == "__proto__" || k == "__count__" || k == "__class__" || k == "reflect")
                  continue;
              var v = o[ k ];
              k = app.stringIDToTypeID(k);
              switch ( typeof(v) ) {
                  case "boolean":
                      d.putBoolean(k, v);
                      break;
                  case "string":
                      d.putString(k, v);
                      break;
                  case "number":
                      d.putDouble(k, v);
                      break;
                  default:
                      if ( v instanceof UnitValue ) {
                          var uc = new Object;
                          uc["px"] = charIDToTypeID("#Pxl"); // pixelsUnit
                          uc["%"] = charIDToTypeID("#Prc"); // unitPercent
                          d.putUnitDouble(k, uc[v.type], v.value);
                      } else {
                          throw( new Error("Unsupported type in objectToDescriptor " + typeof(v) ) );
          return d;
      // Function: descriptorToObject
      // Usage: update a JavaScript Object from an ActionDescriptor
      // Input: JavaScript Object (o), current object to update (output)
      //        Photoshop ActionDescriptor (d), descriptor to pull new params for object from
      //        JavaScript Function (f), post process converter utility to convert
      // Return: Nothing, update is applied to passed in JavaScript Object (o)
      // NOTE: Only boolean, string, number and UnitValue are supported, use a post processor
      function descriptorToObject (o, d, s, f) {
          var l = d.count;
          if (l) {
              var keyMessage = app.charIDToTypeID( 'Msge' );
              if ( d.hasKey(keyMessage) && ( s != d.getString(keyMessage) )) return;
              var k = d.getKey(i); // i + 1 ?
              var t = d.getType(k);
              strk = app.typeIDToStringID(k);
              switch (t) {
                  case DescValueType.BOOLEANTYPE:
                      o[strk] = d.getBoolean(k);
                      break;
                  case DescValueType.STRINGTYPE:
                      o[strk] = d.getString(k);
                      break;
                  case DescValueType.DOUBLETYPE:
                      o[strk] = d.getDouble(k);
                      break;
                  case DescValueType.UNITDOUBLE:
                      uc[charIDToTypeID("#Rlt")] = "px"; // unitDistance
                      uc[charIDToTypeID("#Prc")] = "%"; // unitPercent
                      uc[charIDToTypeID("#Pxl")] = "px"; // unitPixels
                      var ut = d.getUnitDoubleType(k);
                      var uv = d.getUnitDoubleValue(k);
                      o[strk] = new UnitValue( uv, uc[ut] );
                      break;
                  case DescValueType.INTEGERTYPE:
                  case DescValueType.ALIASTYPE:
                  case DescValueType.CLASSTYPE:
                  case DescValueType.ENUMERATEDTYPE:
                  case DescValueType.LISTTYPE:
                  case DescValueType.OBJECTTYPE:
                  case DescValueType.RAWTYPE:
                  case DescValueType.REFERENCETYPE:
                  default:
                      throw( new Error("Unsupported type in descriptorToObject " + t ) );
              o = f(o);
      // Function: SizeInfo
      // Usage: object for holding the dialog parameters
      // Input: <none>
      // Return: object holding the size info
      function SizeInfo() {
          this.height = new UnitValue( 0, "px" );
          this.width = new UnitValue( 0, "px" );
          this.limit = false;
      // Function: NumericEditKeyboardHandler
      // Usage: Do not allow anything except for numbers 0-9
      // Input: ScriptUI keydown event
      // Return: <nothing> key is rejected and beep is sounded if invalid
      function NumericEditKeyboardHandler (event) {
          try {
              var keyIsOK = KeyIsNumeric (event) ||
                            KeyIsDelete (event) ||
                            KeyIsLRArrow (event) ||
                            KeyIsTabEnterEscape (event);
              if (! keyIsOK) {
                  //    Bad input: tell ScriptUI not to accept the keydown event
                  event.preventDefault();
                  /*    Notify user of invalid input: make sure NOT
                         to put up an alert dialog or do anything which
                               requires user interaction, because that
                               interferes with preventing the 'default'
                               action for the keydown event */
                  app.beep();
          catch (e) {
              ; // alert ("Ack! bug in NumericEditKeyboardHandler: " + e);
      //    key identifier functions
      function KeyHasModifier (event) {
          return event.shiftKey || event.ctrlKey || event.altKey || event.metaKey;
      function KeyIsNumeric (event) {
          return  (event.keyName >= '0') && (event.keyName <= '9') && ! KeyHasModifier (event);
      function KeyIsDelete (event) {
          //    Shift-delete is ok
          return ((event.keyName == 'Backspace') || (event.keyName == 'Delete')) && ! (event.ctrlKey);
      function KeyIsLRArrow (event) {
          return ((event.keyName == 'Left') || (event.keyName == 'Right')) && ! (event.altKey || event.metaKey);
      function KeyIsTabEnterEscape (event) {
          return event.keyName == 'Tab' || event.keyName == 'Enter' || event.keyName == 'Escape';
      // End Fit Image.jsx
