16 Replies Latest reply on Dec 29, 2011 12:14 PM by Bernd Alheit
    how to define hidden field
    sindhuxyz Level 1
      I have to use submitForm by http, I have some hidden fields and some input fileds. I am facing problem how to define hidden fields with aFields?
        • 1. Re: how to define hidden field
          When you submit the form using this method, it doesn't matter if the fields
          are hidden or not. If you specify them to be submitted, their value is sent
          irregardless of their visibility.
          • 2. Re: how to define hidden field
            sindhuxyz Level 1
            Thanks for quick response.
            Bascially, I have html form with 2 input fields and 1 hidden fields. I have created same form using Adobe Javascript, I have created text fields for input from user, but how to manage hidden fields?
            I tried:
            Put hidden field in pdf document as text filed and used below code:
            var f = myOdoc.getField("hidden_id");
            var aSubmitFields = new Array( f,"name", "email");
            myOdoc.submitForm({
            cURL: "https://app.getresponse.com/add_contact_webform.html",
            aFields: aSubmitFields,
            cSubmitAs: "HTML"
            "name", "email" are 2 input fields in Javascript Dialog pop.
            It did not work
            Any advise?
            • 3. Re: how to define hidden field
              You just need to add the name of the hidden field to your aSubmitFields
              array, instead of the actual field object, like so:
              var aSubmitFields = new Array( "hidden_id" , "name", "email");
              • 4. Re: how to define hidden field
                sindhuxyz Level 1
                Strangly, hidden field(in pdf document) is picked but text fields in Dialog popup is not taken, can you please advise me what is problem here?
                • 5. Re: how to define hidden field
                  Not sure what you mean... Are you talking about a dialog that you defined
                  in the script? If so, that's just a temporary object which can be
                  submitted. But you can assign the values entered into the dialog to fields
                  (hidden or visible) and then submit them like that.
                  • 6. Re: how to define hidden field
                    sindhuxyz Level 1
                    I tried this:
                    var aSubmitFields = new Array;
                    aSubmitFields["webform_id"] = "134688";
                    aSubmitFields["name"] = "mack";
                    aSubmitFields["email"] = "mack50@yahoo.com";
                    this.submitForm({cURL: "https://app.getresponse.com/add_contact_webform.html",aFields: aSubmitFields,cSubmitAs: "HTML"     });
                    but it is not working, error is webform_id is missing. Can you please guide me how to use submitForm like this?
                    • 7. Re: how to define hidden field
                      The aSubmitFields needs to contain just the names of the fields you want to submit. Their values are automatically collected by the script.
                      So it should be:
                      var aSubmitFields = ["webform_id", "name", "email" ];
                      this.submitForm({cURL: "https://app.getresponse.com/add_contact_webform.html",aFields: aSubmitFields,cSubmitAs: "HTML"});
                      • 8. Re: how to define hidden field
                        sindhuxyz Level 1
                        but I cannot mention all fiels like
                        because one field is hidden and I cannot display it thats why cannot use it like above. Please guide me how to handle it? One field is hidden and I can only use below if all fields are visible or input from user
                        • 9. Re: how to define hidden field
                          As I told you earlier, it doesn't matter if the field is hidden or visible.
                          • 10. Re: how to define hidden field
                            sindhuxyz Level 1
                            but I do not know if it ispossible to define a field which is hidden to user? Please guide me on it
                            • 11. Re: how to define hidden field
                              Yes. Right-click it with the Object Select tool, go to Properties, and
                              under Visibility select Hidden.
                              • 12. Re: how to define hidden field
                                sindhuxyz Level 1
                                I kow it but this is all about Javascript, how to to display off lnam text field?
                                Here is code:
                                var dialog1 = {
                                        initialize: function (dialog) {
                                            // Create a static text containing the current date.
                                            var todayDate = dialog.store()["date"];
                                            todayDate = "Date: " + util.printd("mmmm dd, yyyy", new Date());
                                            dialog.load({ "date": todayDate });
                                        commit:function (dialog) { // called when OK pressed
                                            var results = dialog.store();
                                            // Now do something with the data collected, for example,
                                            console.println("Your name is " + results["fnam"]
                                                + " " + results["lnam"] );
                                        description:
                                            name: "Personal Data",    // Dialog box title
                                            align_children: "align_left",
                                            width: 350,
                                            height: 200,
                                            elements:
                                                    type: "cluster",
                                                    elements:
                                                            type: "view",
                                                            align_children: "align_row",
                                                            elements:
        type: "static_text",
        name: "First Name: "
        item_id: "fnam",
        type: "edit_text",
        alignment: "align_fill",
        width: 300,
        height: 20
                                                            type: "view",
                                                            elements:
        name: "Last Name: "
        item_id: "lnam",
        type: "edit_text",
        width: 300,
        height: 20
                                                            char_width: 25,
                                                            item_id: "date"
                                                    alignment: "align_right",
                                                    type: "ok_cancel",
                                                    ok_name: "Ok",
                                                    cancel_name: "Cancel"
                                    app.execDialog(dialog1);
                                • 13. Re: how to define hidden field
                                  Are you talking about fields in a dialog or in a form? What's the point of
                                  having hidden fields in a dialog?
                                  • 14. Re: how to define hidden field
                                    Bernd Alheit Adobe Community Professional & MVP
                                    I tried:
                                    myOdoc.submitForm({
                                    cSubmitAs: "HTML"
                                    It did not work
                                    Any advise?
                                    You can only submit fields of a form, not of dialog.
                                    • 15. Re: how to define hidden field
                                      sindhuxyz Level 1
                                      Is it possible to create submit fields of a form dynamically in Javascript? I am submitting a html form by Adobe Javascript which has hidden fields(predefined values) and input fields(input from user).
                                      • 16. Re: how to define hidden field
                                        You can't submit a HTML form. You can submit form data in HTML format. For this you defines the form fields in Acrobat and adds a submit button.
