2 Replies Latest reply on Dec 28, 2011 5:17 AM by Vikash.kumar29
    Garbage collection problem with Air
    Vikash.kumar29 Level 3
      Hi all,
      I have a titlewindow component added using PopupManager.addPopup method and removed using the removePopup method of PopupManager. When I profile the application using profiler of Flash Builder then I noticed that instances of TitleWidow are not Garbage collected.
      This happens only in the case of Air projects however this is working fine in web projects.
      Just for information I am using Adobe Air 3.1 with Flex Sdk 4.5.1
      For this I have created a sample windowed application and found that same problem persist there.
      Here is my sample code to reproduce the scenario:
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:mx="library://ns.adobe.com/flex/mx">
       <fx:Script>
        <![CDATA[
         import mx.events.FlexEvent;
         import mx.managers.PopUpManager;
         import spark.components.TitleWindow;
         private var tw:TitleWindow;
         protected function button1_clickHandler(event:MouseEvent):void
           tw = new TitleWindow();
          PopUpManager.addPopUp(tw, this);
         protected function button2_clickHandler(event:MouseEvent):void
          PopUpManager.removePopUp(tw);
          tw = null;
       </fx:Script>
       <s:layout>
        <s:VerticalLayout verticalAlign="middle" horizontalAlign="center" />
       </s:layout>
       <s:Button label="Add Popup" click="button1_clickHandler(event)"/>
       <s:Button label="Remove Popup" click="button2_clickHandler(event)"/>
      </s:WindowedApplication>
      Please do let know, where I am going wrong. Any help will be appreciated.
      -Thanks and Regards
      Vikash kumar
