1. Re: Gradient proper blend and Bigger color picker.
Wade_Zimmerman Dec 27, 2011 8:42 PM (in response to Amaterasu555)You are comparing Apples and Oranges that is why it desn't make sense to you.
The Photoshop document you are working is in RGB color Mode and the Illustrator document you are working on is CMYK.
One is light the other is ink pigments.
Here are screen shots of the same gradient fill in Illustrator one is RGB and the other converted to CMYK.
No matter what you make happen ofn the screen in reality the colors when printed on paer are going to much duller on paper but as human beings we tend to compensate for that until you do a side by side comparison so all the beautiful coloryou see in printed material of a CMYK nature is mostly in the mind's eye.
Here se for your self
RGB
CMYK (same document converted.)
2. Re: Gradient proper blend and Bigger color picker.
Wade_Zimmerman Dec 27, 2011 8:53 PM (in response to Wade_Zimmerman)What you can do is create a shape path and fill it with a color say the purple violet and
then in the apprearance panel add a new fill
make that say a black to black gradient with one end 100% opcaity and the other end 0% Opacity
You get this you essentially are making a rich black as a gradient overlay that would probably give you what you are seeking.
Do the same with gradients that will not contain black
If it is for the web then just use RGB
3. Re: Gradient proper blend and Bigger color picker.
Amaterasu555 Dec 28, 2011 1:10 AM (in response to Wade_Zimmerman)Oh I see.So CMYK will have that grey shade right?Got it.Thanks a lot.No,I mostly use Illustrator for print stuff only.And I guess,your work around of Black-Black gradient will do perfect for me.
Any work around or solution for a bigger color picker?
4. Re: Gradient proper blend and Bigger color picker.
Wade_Zimmerman Dec 28, 2011 4:52 AM (in response to Amaterasu555)As far as the larger color picker I would say a feature request? Or perhaps resizing the gradient panel I am not at my computer so I can't shy that will help?
5. Re: Gradient proper blend and Bigger color picker.
[scott] Dec 29, 2011 3:04 AM (in response to Wade_Zimmerman)Double clicking a color box brings up the OS color picker. It's not as integrated into AI as it is in PS.. but it's there.
6. Re: Gradient proper blend and Bigger color picker.
imjeffp Jan 9, 2012 2:21 PM (in response to Amaterasu555)Instead of blending from 55, 87, 0, 0 to 0, 0, 0, 100, blend from 55, 87, 0, 0 to 55, 87, 0, 100.
