3 Replies Latest reply on Jan 3, 2012 8:51 AM by Carol L. Frampton
    Flex4 styling issue
    sudhansurana Level 1
      Hi
      I have created custom advancedDatagrid component while extending AdvancedDatagrid.
      After embedding fonts it is showing the following issue.
      in CSS
      mx|global
                                    font-family:Arial;
                                    color:#000000;
                                    modal-transparency: 0.5;
                                    modal-transparency-color: #333333;
                                    modal-transparency-blur:0.5;
         textFieldClass: ClassReference("mx.core.UIFTETextField");
                          @font-face {
                                    src: url("ARIAL.TTF");
                                    fontFamily: Arial;
                                    fontStyle: normal  ;
                                    fontWeight: normal  ;
                                    embedAsCFF:true ;
                                    advancedAntiAliasing: true ;
      Error: 'restrict' is not implemented in FTETextField.
                at mx.core::FTETextField/set restrict()[E:\dev\4.0.0\frameworks\projects\spark\src\mx\core\FTETextField.as:1357]
                at mx.controls::TextInput/commitProperties()[E:\dev\4.0.0\frameworks\projects\framework\src\ mx\controls\TextInput.as:1787]
                at mx.core::UIComponent/validateProperties()[E:\dev\4.0.0\frameworks\projects\framework\src\ mx\core\UIComponent.as:7772]
                at mx.managers::LayoutManager/validateProperties()[E:\dev\4.0.0\frameworks\projects\framewor k\src\mx\managers\LayoutManager.as:572]
                at mx.managers::LayoutManager/doPhasedInstantiation()[E:\dev\4.0.0\frameworks\projects\frame work\src\mx\managers\LayoutManager.as:700]
                at mx.managers::LayoutManager/doPhasedInstantiationCallback()[E:\dev\4.0.0\frameworks\projec ts\framework\src\mx\managers\LayoutManager.as:1072]
      Please help me fix this Issue.
      Sudhansu
        • 1. Re: Flex4 styling issue
          Adding styling to mx TextInput show the above error.
          mx|TextInput
                                        font-family:Arial;
                                        color:#000000;
                                        font-size:12;
          • 2. Re: Flex4 styling issue
            drkstr_1 Level 4
            I didn't think FTE worked with the older (mx) TextInput classes, but I could be wrong....
            What is the specific reason you are attempting to do it this way?
            • 3. Re: Flex4 styling issue
              Carol L. Frampton Level 2
              Only some of the mx controls work (in particular those that don't have spark equivalents) with mx.core.UIFTETextField.
              As you can see mx:TextInput does not work.
