2 Replies Latest reply on Mar 26, 2015 1:38 AM by Raghavank
    Flex Print Job not working with custom component
    jigarinu
      Hi All,
      I have to print pages with header, body and footer. So the thought process was to create a custom component fro header, footer and body. Header component is based on Box, Body is a renderer (which will have fix value of items - and will decide the number of possible pages) and footer is again based on Box.
      But when i created a simple Custom component like this for header
      <mx:VBox  xmlns:fx=http://ns.adobe.com/mxml/2009
        xmlns:mx="library://ns.adobe.com/flex/mx">
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <mx:HBox>
           <mx:Label id="testLabel" text="Test Container"/>
      </mx:HBox>
      </mx:VBox>
      Then when i try to add this to FlexPrintJob, and save it as 'xps' to see the print output, i get error message that this file is in use or damaged.
        var myPrintJob:FlexPrintJob = new FlexPrintJob();
         if(!myPrintJob.start()){
            return;
       var header:Header = new Header();
      header.width = myPrintJob.pageWidth;
      header.visible = false;
      FlexGlobals.topLevelApplication.addChild(panierPrintHeader);
      myPrintJob.addObject(header);
      myPrintJob.send();
      FlexGlobals.topLevelApplication.removeChild(panierPrintHeader);
      But this does not work and i get the above mentioned exception. Now when i not
      use the custom component and just have a label or HBox or anything on stage before the print functionality is invoked, it works fine. And this too haapens only if you have a mxml component, i tried by creating a new Label component using actionscript and then provide the same to the printJob, which did not work either. I need help on this, else i will have to take print functionality to server side(Java) which has some business implications, the reason why i am spending time on flex for printing.
      Thanks and Regards,
      Jigar
      Looks like custom component print is not working fine with flex or i am doing something terribly wrong.
      Looking forward for help.
