22 Replies Latest reply on Jan 3, 2012 4:27 AM by c.pfaffenbichler
    Is possible to separate path using script....?
    yajiv_viki Level 2
      Hi Everyone,
      I have one overall path and two outer edge path.
      use overall path to separate each like pant and tops.
      Is possible to separate path using script. I have also tried script but is not working on second separation.
      can any rectify that script is possible...?
      -yajiv
      #target Photoshop
      app.bringToFront;
      var docRef = app.activeDocument;
      var myDocname=app.activeDocument.name
      var e=0
      try {
          var ecp=docRef.colorProfileName;
           var n=docRef.pathItems.length;
                          if(n>0){
                  if(docRef.pathItems[0].name=="Path 1"){
                    var pathRef = docRef.pathItems[0].duplicate();
                    var path1=docRef.pathItems.getByName("1");
                    //path1.duplicate();
                    path1.select();
                    Path_copy();
                    var pathitem=docRef.pathItems.getByName("Path 1 copy");
                     pathitem.select();
                     Path_Paste();
                     pathitem.operation = ShapeOperation.SHAPEINTERSECT;
                     Path_Combine();
                     var pathRef1 = path1.duplicate();
                     path1.select();
                     path1.remove();
                      pathitem.select();
                      pathitem.name="1";
                      var pathitem=docRef.pathItems.getByName("Box");
                      pathitem.select();
                      Path_copy();
                     var path1=docRef.pathItems.getByName("1 copy");
                      path1.select();
                      path1.name="OL"
                      Path_Paste();
                      path1.operation = ShapeOperation.SHAPEXOR;
                      Path_Combine();
                     pathitem.select();
                     Path_copy();
                     var path2=docRef.pathItems.getByName("OL");
                     path2.select();
                     Path_Paste();
                     path2.operation = ShapeOperation.SHAPEINTERSECT;
                     alert(path2.operation);
                     Path_Combine();
      catch (e) {
         alert(e);
      //alert ("PSR_LWC_PLUS_V2_PT - Color Profile not Embedded...\n Check it out...!!!")
      function Path_copy(){
          var id200 = charIDToTypeID( "copy" );
          executeAction( id200, undefined, DialogModes.NO );
      function Path_Paste(){
          var id204 = charIDToTypeID( "past" );
          executeAction( id204, undefined, DialogModes.NO );
      function Path_Combine(){
                  var idcombine = stringIDToTypeID( "combine" );
                      var desc26 = new ActionDescriptor();
                      var idnull = charIDToTypeID( "null" );
                          var ref25 = new ActionReference();
                          var idPath = charIDToTypeID( "Path" );
                          var idOrdn = charIDToTypeID( "Ordn" );
                          var idTrgt = charIDToTypeID( "Trgt" );
                          ref25.putEnumerated( idPath, idOrdn, idTrgt );
                      desc26.putReference( idnull, ref25 );
                  executeAction( idcombine, desc26, DialogModes.NO );
        • 1. Re: Is possible to separate path using script....?
          c.pfaffenbichler Level 9
          I may not quite follow.
          Could you post a screenshot/mock-up to show how the path is currently set up and what paths or selections you want to generate off of it exactly?
          I guess it may be necessary to process all of the pathItem’s subPathItems and create new Working Paths from that information; but that should not be too hard to do.
          • 2. Re: Is possible to separate path using script....?
            yajiv_viki Level 2
            Sure!
            Please Find my attachment...!
            anyone help me to do next step....?
            -yajiv
            • 3. Re: Is possible to separate path using script....?
              In your original Script why do you select the path »Box«?
              And to ensure the operation goes as planned even with paths that have »holes« maybe you should apply »Path_Combine()« on each path before copying?
              • 4. Re: Is possible to separate path using script....?
                yajiv_viki Level 2
                Hi c.pfaffenbichler,
                I have followed the below mentioned steps.(script also followed by this steps)
                • First I have one Overall Path name as Path1, two outer edge path for seprate overall path like pant & Tops
                       Path "1" for outer edge of Pant.
                       Path "2" for outer edge of Tops.
                       Path "Box" used for invert the all outer edge Path.
                Step 1:
                          Duplicate Path 1 like "Path 1 copy". then Copy "1"  and Paste to "Path1 copy".
                          Intersect all path and Combine like below figure.
                Step 2.
                          Rename "Path 1 copy" to "Pant". Now Copy "Box" and Paste to "1" then Select path to exculde & Combine like below figure.
                Step 3:
                          Intersect all path and Combine like below figure. Remove Path "1" and rename "Path 1 copy" to "OL".
                          OL Path means overall path except Pant part.
                Step 4:
                            Duplicate OL like "OL copy". then Copy "2"  and Paste to "OL copy".
                            Intersect all path and Combine like below figure. Rename "OL copy" to "Tops".
                Step 5. Now Copy "2" and Paste to "Box" then Select path to exculde & Combine like below figure.
                            and Remove Path "2".
                Step 6. Now Copy "Box" and Paste to "OL" then Select path to Intersect & Combine like below figure.
                            and Remove Path "Flesh". & Remove Path "Box".
                That's It.
                -yajiv
                • 5. Re: Is possible to separate path using script....?
                  I wonder if you could streamline the Script some more – but if I understand you correctly and it works in its current incarnation that might be nitpicking.
                  Should you run it on batches of images you could wrap all or parts of the operation in try-clauses to avoid the process stopping in case an image’s paths don’t conform to the naming-convention.
                  • 6. Re: Is possible to separate path using script....?
                    yajiv_viki Level 2
                    Can you one do my favuore if Possible..?
                    Is this possible to select Path nodes. Like below image.
                    If I select more than one closed and apply Path operation like shapeOperation.SHAPEINTERSECT & combine path.
                    Thanks in advance.
                    Note: Select all nodes from path not a select path in Path palette.
                    Regards,
                    - yajiv
                    • 7. Re: Is possible to separate path using script....?
                      As far as I can tell: no.
                      But one can get the complete path information and create a new Path where one can set the subPathItems to that shapeOperation.
                      Unfortunately this can run into problems with paths that have »holes«.
                      But if I may conjecture on your workflow:
                      One could get the information from the first path (the complete figure) and add the information from the third path (the trousers) and set those to intersect.
                      • 8. Re: Is possible to separate path using script....?
                        yajiv_viki Level 2
                        Thanks for your kind reply.
                        I will try to do some modification & slove this script in future.
                        Once again Thanks for your continue support till secs.
                        "Happy New Year...!!!"
                        Regards
                        -yajiv....
                        • 9. Re: Is possible to separate path using script....?
                          You could give the Script below a try, but be aware that I have not yet tested it very thoroughly.
                          It would not need a »box«-path; in the screeshot you can see what the resulting paths are for the three original paths.
                          If you want the paths to be combined you could add the function after the creation of each of the resultant paths.
                          // create path intersections;
                          // 2011; use it at your own risk;
                          #target photoshop
                          if (app.documents.length > 0) {
                          var myDocument = app.activeDocument;
                          // set to pixels;
                          var originalRulerUnits = app.preferences.rulerUnits;
                          app.preferences.rulerUnits = Units.POINTS;
                          var theArray = new Array;
                          var theNumber = myDocument.pathItems.length;
                          // »simplify« paths and collect components;
                          for (var m = 0; m < theNumber; m++) {
                                    myDocument.pathItems[m].select();
                                    combinePath();
                                    theArray.push(collectPathComponents(myDocument, myDocument.pathItems[m]));
                          // create intersections;
                          for (var n = 1; n < theNumber; n++) {
                                    var theFirst = collectPathComponents(myDocument, myDocument.pathItems[0]);
                                    var theSecond = theArray[n];
                                    for (var a = 0; a < theSecond.length; a++) {
                                              theFirst.push(theSecond[a])
                                    var thePath = createPathFromPathComponentActionDesc(theFirst, "intersect");
                                    makePath("path_"+Math.random());
                          // create subtraction;
                          for (var o = 1; o < theNumber; o++) {
                                    var theSecond = theArray[o];
                          var thePath = createPathFromPathComponentActionDesc(theFirst, "subtract");
                          // reset;
                          app.preferences.rulerUnits = originalRulerUnits;
                          function combinePath () {
                              var desc4 = new ActionDescriptor();
                                  var ref3 = new ActionReference();
                                  ref3.putEnumerated( idPath, idOrdn, idTrgt );
                              desc4.putReference( idnull, ref3 );
                          executeAction( idcombine, desc4, DialogModes.NO );
                          //components correspond to subPathItems,  subpathList contains the actual paths than can make up one subPathItem ;
                          ////// collect path infor from actiondescriptor //////
                          function collectPathComponents (myDocument, thePath) {
                          //var myDocument = app.activeDocument;
                          // based of functions from xbytor’s stdlib;
                          var ref = new ActionReference();
                          for (var l = 0; l < myDocument.pathItems.length; l++) {
                                    var thisPath = myDocument.pathItems[l];
                                    if (thisPath == thePath && thisPath.name == "Work Path") {
                                              ref.putProperty(cTID("Path"), cTID("WrPt"));
                                    if (thisPath == thePath && thisPath.name != "Work Path" && thisPath.kind != PathKind.VECTORMASK) {
                                              ref.putIndex(cTID("Path"), l + 1);
                                    if (thisPath == thePath && thisPath.kind == PathKind.VECTORMASK) {
                                  var idvectorMask = stringIDToTypeID( "vectorMask" );
                                  ref.putEnumerated( idPath, idPath, idvectorMask );
                          var desc = app.executeActionGet(ref);
                          var pname = desc.getString(cTID('PthN'));
                          // create new array;
                          var pathContents = desc.getObjectValue(cTID("PthC"));
                          var pathComponents = pathContents.getList(sTID('pathComponents'));
                          for (var m = 0; m < pathComponents.count; m++) {
                          var comp = pathComponents.getObjectValue(m);
                          var subPathList = comp.getList(sTID("subpathListKey"));
                          var shapeOp = comp.getEnumerationType(sTID("shapeOperation"));
                          theArray.push([comp, subPathList, shapeOp]);
                          // by xbytor, thanks to him;
                          function cTID (s) { return cTID[s] || cTID[s] = app.charIDToTypeID(s); };
                          function sTID (s) { return sTID[s] || sTID[s] = app.stringIDToTypeID(s); };
                          // reset;
                          return theArray;
                          ////// create a path from an array of pathcomponents //////
                          function createPathFromPathComponentActionDesc (theArray, shapeOperation) {
                          cTID = function(s) { return app.charIDToTypeID(s); };
                          sTID = function(s) { return app.stringIDToTypeID(s); };
                          var desc1 = new ActionDescriptor();
                          var ref1 = new ActionReference();
                          ref1.putProperty(cTID('Path'), cTID('WrPt'));
                          desc1.putReference(sTID('null'), ref1);
                          var list1 = new ActionList();
                          for (var m = 0; m < theArray.length; m++) {
                                    var desc37 = new ActionDescriptor();
                                    if (m == 0) {
                                              desc37.putEnumerated(sTID('shapeOperation'), sTID('shapeOperation'), cTID('Intr'));
                                    else {
                                              switch (shapeOperation) {
                                                        case "intersect":
                                                        break;
                                                        case "subtract":
                                                        desc37.putEnumerated(sTID('shapeOperation'), sTID('shapeOperation'), cTID('Sbtr'));
                                                        break;
                                                        default:
                                                        desc37.putEnumerated(sTID('shapeOperation'), sTID('shapeOperation'), theArray[m][2]);
                                                        break;
                                    var list5 = new ActionList();
                                    desc37.putList(cTID('SbpL'), theArray[m][1]);
                                    list1.putObject(cTID('PaCm'), desc37);
                          desc1.putList(cTID('T   '), list1);
                          executeAction(cTID('setd'), desc1, DialogModes.NO);
                          ////// make work path regular path //////
                          function makePath (aName) {
                          var idMk = charIDToTypeID( "Mk  " );
                                  var ref2 = new ActionReference();
                                  ref2.putClass( idPath );
                              desc4.putReference( idnull, ref2 );
                              var idFrom = charIDToTypeID( "From" );
                                  var idWrPt = charIDToTypeID( "WrPt" );
                                  ref3.putProperty( idPath, idWrPt );
                              desc4.putReference( idFrom, ref3 );
                              var idNm = charIDToTypeID( "Nm  " );
                              desc4.putString( idNm, aName );
                          executeAction( idMk, desc4, DialogModes.NO );
                          • 10. Re: Is possible to separate path using script....?
                            yajiv_viki Level 2
                            Hi
                            That's exactly what I was trying to achieve!
                            Thank you for your time and knowledge, I really do appreciate it.
                            Once again Thanks for your continue support.
                            "Wish you Happy successful New Year - 2012...!!!"
                            Regards
                            -yajiv....
                            • 11. Re: Is possible to separate path using script....?
                              I made some small changes, please try this one:
                              #target photoshop
                              // set to pixels;
                                   if (myDocument.pathItems[m].subPathItems.length > 1) {
                                        combinePath();
                                   makePath(myDocument.pathItems[0].name" intersected with "myDocument.pathItems[n].name);
                                   combinePath ()
                              makePath("all others subtracted from "+myDocument.pathItems[0].name);
                              combinePath ();
                              // reset;
                              theArray.push();
                              // reset;
                              return theArray;
                                   if (m == 0) {
                                        desc37.putEnumerated(sTID('shapeOperation'), sTID('shapeOperation'), theArray[m][1]);
                                   else {
                                             case "intersect":
                                             break;
                                             case "subtract":
                                             break;
                                             default:
                                             break;
                                   desc37.putList(cTID('SbpL'), theArray[m][0]);
                              • 12. Re: Is possible to separate path using script....?
                                Your last reply seems to have failed posting.
                                What was the error?
                                • 13. Re: Is possible to separate path using script....?
                                  yajiv_viki Level 2
                                  If I run the script, Error occur in Line 153: illegal argument - argument 2
                                  like below mentioned image.
                                  Regards
                                  -yajiv
                                  • 14. Re: Is possible to separate path using script....?
                                    It seems the last Script I posted was garbled …
                                    It should have been:
                                    #target photoshop
                                    // set to pixels;
                                                        combinePath();
                                              makePath(myDocument.pathItems[0].name+" intersected with "+myDocument.pathItems[n].name);
                                              combinePath ()
                                    combinePath ();
                                    // reset;
                                    theArray.push([subPathList, shapeOp]);
                                    // reset;
                                    return theArray;
                                              if (m == 0) {
                                              else {
        case "intersect":
        break;
        case "subtract":
        break;
        default:
        break;
                                    If that is the reason for the error I’m not sure.
                                    The error seems to occur at naming the work path, so it could be about the paths’ names – are they especially long or do they have possibly problematic characters?
                                    Have you removed the »box«-path?
                                    • 15. Re: Is possible to separate path using script....?
                                      yajiv_viki Level 2
                                      Its work fine. after getting result with leak path.
                                      I got one method to rectify above leaks, can you tell is this possible or not.
                                      As per step your script
                                      1. Collect information both Overall Path and outer-edge path then Intersect & Combine we get Tops.
                                      after that we collect information both Overall Path and outer-edge path1 then we Subtract & Combine we get Overall path exclude Tops.
                                      2. Collect information both Overall path exclude Tops and outer-edge path2 then Intersect & Combine we get Pant.
                                      again we collect information both Overall path exclude Tops and outer-edge path2 then we Subtract & Combine we get Flesh path.
                                      is this possible....?
                                      Regards,
                                      -yajiv
                                      Note : I have some modification your code but error happened in Line 97 and 122
                                      Error : General Photoshop Error occurred. This function may not be available in this version of photoshop.
                                      Can you rectify this...?
                                      #target photoshop
                                      // set to pixels;
                                                combinePath();
                                            var OV_Path=myDocument.pathItems[0] // modified myself
                                              //alert(OV_Path);
                                                var theFirst = collectPathComponents(myDocument,OV_Path );
                                                          theFirst.push(theSecond[a]);
                                                combinePath();
                                               var i=1;//modified myself
                                               makePath("OL_"+i);
                                               OV_Path="OL_"+i;
                                               combinePath();
                                               i=i+1;
                                      combinePath();
                                      // reset;
                                      // reset;
                                      return theArray;
                                                if (m == 0) {
                                                else {
        case "intersect":
        break;
        case "subtract":
        break;
        default:
        break;
                                      • 16. Re: Is possible to separate path using script....?
                                        What good is the outer edge path?
                                        The paths that circumscribe the person and the various textiles should suffice.
                                        But maybe I am misuderstanding your procedure – could you illustrate the steps with screenshots or a mock-up?
                                        • 17. Re: Is possible to separate path using script....?
                                          yajiv_viki Level 2
                                          Here I attched video for refernece for Sepration path.
                                          Thanks in advance.
                                          Please watch this video....
                                          https://www.youtube.com/watch?v=xYN-k6N19ag
                                          -yajiv
                                          • 18. Re: Is possible to separate path using script....?
                                            yajiv_viki Level 2
                                            Thanks in advance.
                                            Note Please copy link & paste to address bar in browser.
                                            Actually I need to some modification your script.
                                            As per your script:
                                            1. We have collect path information include Overall Path and Intersct & Combine Right.
                                            2. now second step per your script. We have collect include Overall path information and Subtract & Combine Right.
                                            I need to change this step 2. In subtract menthod..
                                            We have collect all path information and Add & Combine except Overall path. change mode to exclude. give name to "OL"
                                            1. now duplicate overall path.
                                            2. Copy "OL" & paste to duplicate overall path.
                                            3. now subtract & Combine path we get the result of flesh path.
                                            is this possible.
                                            -yajiv
                                            • 19. Re: Is possible to separate path using script....?
                                              In the Script you marked out the part
                                              combinePath();
                                              that should do what you show in the movie you posted regarding a path for everything except the textiles.
                                              Sorry, but I’m afraid I still don’t quite follow the problem.
                                              Just to make sure (and to run tests) could you post a jpg of one of your images (blank out the layer to avoid copyright issues but keep the paths) on this Forum?
                                              • 20. Re: Is possible to separate path using script....?
                                                yajiv_viki Level 2
                                                Please modify below mentioned your script as per my instruction.
                                                combinePath();
                                                Please change the script below mentioned instruction if you are possible with it...?
                                                1. We have collected all paths information and Add & Combine except Overall path. change mode to exclude. give name to "OL"
                                                2. now duplicate overall path.
                                                3. Copy "OL" & paste to duplicate overall path.
                                                4. now subtract & Combine path we get the result of flesh path.
                                                5. Finally all path should be exclude mode.
                                                Regards,
                                                    - yajiv
                                                • 21. Re: Is possible to separate path using script....?
                                                  yajiv_viki Level 2
                                                  Finally with your guidance I rectify the script error.
                                                  Regards
                                                  -yajiv....
                                                  Here is the Code.....!
                                                  #target photoshop
                                                  // set to pixels;
                                                            combinePath();
                                                          //alert(OV_Path);
                                                            var thePath = createPathFromPathComponentActionDesc(theFirst, "intersect",0);
                                                            combinePath();
                                                      var thePath = createPathFromPathComponentActionDesc(theFirst, "subtract",1); // Modify the parameter, add flag for function
                                                      //subtract
                                                      combinePath();
                                                  // reset;
        // var idPath = charIDToTypeID( "Path" );
                                                          //alert("shapeOp - "+shapeOp);    q
                                                          // reset;
                                                          return theArray;
                                                      function createPathFromPathComponentActionDesc (theArray, shapeOperation,flag) {
        if (m == 0 && flag=0) {
        else  if (m == 0 && flag=1) {//Modify mode to exclude.....!
        else {
        case "intersect":
        break;
        case "subtract":
        break;
        case "exclude":
        desc37.putEnumerated(sTID('shapeOperation'), sTID('shapeOperation'), 696);
        default:
        break;
                                                  • 22. Re: Is possible to separate path using script....?
                                                    I have been busy today, so I had not read your last post fully – but if I understand correctly that is moot now and you can automate your intended task yourself?
