2 Replies Latest reply: Dec 28, 2011 2:54 PM by Pak762 RSS
    float4x4 problem at program.upload()
    Pak762 Community Member
      Im trying to get my paticle-vertex-shader to work, but for each particle I need to have a different rotation, scaling and position, but this is not the problem right now. The problem is, that I have to use a float4x4 as an variable. Every time I do lets say float4x4 mat = float4x4(1); the PB3D-Compiler is fine about it.
      When compiling the AGAL-program...
      this.m_program.upload(programPair.vertexProgram.byteCode, programPair.fragmentProgram.byteCode);
      it gives me this as an the error:
      AGAL-Überprüfung fehlgeschlagen: Temporärer Registerindex außerhalb des gültigen Bereichs für destination operand bei Token 5 des vertex-Programms.
      In english it sais something like this:
      Agal-Check failed: Temporary registerindex out of range for destination operand at token 5 of the vertex-Program.
      the full vertex-shader:
        input vertex float4 vo <id: "PB3D_POSITION";>; // vertex offset
        output float4 vertexClipPosition;
                parameter float4x4 object;
                parameter float4x4 camera;
         void evaluateVertex()
                          float4x4 m2                 = float4x4(1.0);
                          float4x4 m                   = object * camera * m2;
                          vertexClipPosition           = m * vo;
      Note: This is not the real shader I will use, this is just a test.
      m2 is the problem here, because it is not initialized from an existing one. If I just use the matrices from the parameters, everything works like it should.
      Any ideas what could be wrong here?
        • 1. Re: float4x4 problem at program.upload()
          Ok after reading the doc again, I noticed, that my program uses more than 8 temporary registers. 10 to be exact. Now I managed to get it down to 5, but still, the same error.
          here is the full code of it.
                    input vertex float2 pm; // particle Movement
                    input vertex float2 pp; // particle Position
                    input vertex float  ps; // particle Scale
                 float2 dir     = normalize(pm);
                 float4x4 m  = float4x4(          dir.x, -dir.y, 0.0, 0.0,
        dir.y,  dir.x, 0.0, 0.0,
        0.0,    0.0,   1.0, 0.0,
        0.0,    0.0,   0.0, 1.0);
                 float4 vp                              = vo * ps;
                 vp                                        = m * vp;
                 vp.xy                                  += pp.xy;
                 m                                         = object * camera;
                 vertexClipPosition            = m * vp;
          • 2. Re: float4x4 problem at program.upload()
            after trying out so many cases for hours I have to come to the conclusion, that there has to be an error in PB3D.
            [object ParticleMaterialShader]
            FragmentParameter: color startRegister: 1 offset: 0
            FragmentParameter: texTile startRegister: 2 offset: 0
            VertexParameter: camera startRegister: 5 offset: 0
            VertexInputRegister: pp startRegister: 0
            VertexInputRegister: ps startRegister: 1
            VertexInputRegister: vo startRegister: 2
            VertexInputRegister: UVCoord startRegister: 3
            fragment temp registers: 3
            vertex   temp registers: 6
            It is not working
            Now I have a version that uses just 4 vertex tempregisters. Nothing
            Here is the code:
            output float4 vc;
                                float4x4 m                              = float4x4(1.0);
                                float4 vp                              = m * float4(vo.x, vo.y, 0,0);
                                vp.xy                                   *= ps;
                                vp.xy                                 += pp.xy;
                                vc                                                   = camera * vp;
