2 Replies Latest reply on Dec 29, 2011 12:10 AM by delicious_food
    Why won't Photoshop revert to earlier history state after image resize when scripted?
    delicious_food
      I've written an Applescript to automate watermarking and resizing images for my company. Everything generally works fine — the script saves the initial history state to a variable, resizes the image, adds the appropriate watermark, saves off a jpeg, then reverts to the initial history state for another resize and watermark loop.
      The problem is when I try not to use a watermark and only resize by setting the variable `wmColor` to `"None"` or `"None for all"`. It seems that after resizing and saving off a jpeg, Photoshop doesn't like it when I try to revert to the initial history state. This is super annoying, since clearly a resize should count as a history step, and I don't want to rewrite the script to implement multiple open/close operations on the original file. Does anyone know what might be going on? This is the line that's generating the problem (it's in both the doBig and doSmall methods, and throws an error every time I ask it just to do an image resize and change current history state):
                          set current history state of current document to initialState
      and here's the whole script:
      property type_list : {"JPEG", "TIFF", "PNGf", "8BPS", "BMPf", "GIFf", "PDF ", "PICT"}
      property extension_list : {"jpg", "jpeg", "tif", "tiff", "png", "psd", "bmp", "gif", "jp2", "pdf", "pict", "pct", "sgi", "tga"}
      property typeIDs_list : {"public.jpeg", "public.tiff", "public.png", "com.adobe.photoshop-image", "com.microsoft.bmp", "com.compuserve.gif", "public.jpeg-2000", "com.adobe.pdf", "com.apple.pict", "com.sgi.sgi-image", "com.truevision.tga-image"}
      global myFolder
      global wmYN
      global wmColor
      global nameUse
      global rootName
      global nameCount
      property myFolder : ""
      -- This droplet processes files dropped onto the applet
      on open these_items
        -- FILTER THE DRAGGED-ON ITEMS BY CHECKING THEIR PROPERTIES AGAINST THE LISTS ABOVE
                set wmColor to null
                set nameCount to 0
                set nameUse to null
                if myFolder is not "" then
                          set myFolder to choose folder with prompt "Choose where to put your finished images" default location myFolder -- where you're going to store the jpgs
                else
                          set myFolder to choose folder with prompt "Choose where to put your finished images" default location (path to desktop)
                end if
                repeat with i from 1 to the count of these_items
                          set totalFiles to count of these_items
                          set this_item to item i of these_items
                          set the item_info to info for this_item without size
                          if folder of the item_info is true then
        process_folder(this_item)
                          else
                                    try
                                              set this_extension to the name extension of item_info
                                    on error
                                              set this_extension to ""
                                    end try
                                    try
                                              set this_filetype to the file type of item_info
                                    on error
                                              set this_filetype to ""
                                    end try
                                    try
                                              set this_typeID to the type identifier of item_info
                                    on error
                                              set this_typeID to ""
                                    end try
                                    if (folder of the item_info is false) and (alias of the item_info is false) and ((this_filetype is in the type_list) or (this_extension is in the extension_list) or (this_typeID is in typeIDs_list)) then
        -- THE ITEM IS AN IMAGE FILE AND CAN BE PROCESSED
        process_item(this_item)
                                    end if
                          end if
                end repeat
      end open
      -- this sub-routine processes folders
      on process_folder(this_folder)
                set these_items to list folder this_folder without invisibles
                          set this_item to alias ((this_folder as Unicode text) & (item i of these_items))
                          else
                                    try
                                    on error
                                    end try
                                    try
                                    on error
                                    end try
                                    try
                                    on error
                                    end try
                                    end if
                          end if
                end repeat
      end process_folder
      -- this sub-routine processes files
      on process_item(this_item)
                set this_image to this_item as text
                tell application id "com.adobe.photoshop"
                          set saveUnits to ruler units of settings
                          set display dialogs to never
        open file this_image
                          if wmColor is not in {"None for all", "White for all", "Black for all"} then
                                    set wmColor to choose from list {"None", "None for all", "Black", "Black for all", "White", "White for all"} with prompt "What color should the watermark be?" default items "White for all" without multiple selections allowed and empty selection allowed
                          end if
                          if wmColor is false then
                                    error number -128
                          end if
                          if nameUse is not "Just increment this for all" then
                                    set nameBox to display dialog "What should I call these things?" default answer ("image") with title "Choose the name stem for your images" buttons {"Cancel", "Just increment this for all", "OK"} default button "Just increment this for all"
                                    set nameUse to button returned of nameBox -- this will determine whether or not to increment stem names
                                    set rootName to text returned of nameBox -- this will be the root part of all of your file names
                                    set currentName to rootName
                          else
                                    set nameCount to nameCount + 1
                                    set currentName to rootName & (nameCount as text)
                          end if
                          set thisDocument to current document
                          set initialState to current history state of thisDocument
                          set ruler units of settings to pixel units
                end tell
        DoSmall(thisDocument, currentName, initialState)
        DoBig(thisDocument, currentName, initialState)
                          close thisDocument without saving
                          set ruler units of settings to saveUnits
                end tell
      end process_item
      to DoSmall(thisDocument, currentName, initialState)
                          set initWidth to width of thisDocument
                          if initWidth < 640 then
        resize image thisDocument width 640 resample method bicubic smoother
                          else if initWidth > 640 then
        resize image thisDocument width 640 resample method bicubic sharper
                          end if
                          set myHeight to height of thisDocument
                          set myWidth to width of thisDocument
                          if wmColor is in {"White", "White for all"} then
                                    set wmFile to (path to resource "water_250_white.png" in bundle path to me) as text
                          else if wmColor is in {"Black", "Black for all"} then
                                    set wmFile to (path to resource "water_250_black.png" in bundle path to me) as text
                          end if
                          if wmColor is not in {"None", "None for all"} then
        open file wmFile
                                    set wmDocument to current document
                                    set wmHeight to height of wmDocument
                                    set wmWidth to width of wmDocument
        duplicate current layer of wmDocument to thisDocument
                                    close wmDocument without saving
        translate current layer of thisDocument delta x (myWidth - wmWidth - 10) delta y (myHeight - wmHeight - 10)
                                    set opacity of current layer of thisDocument to 20
                          end if
                          set myPath to (myFolder as text) & (currentName) & "_640"
                          set myOptions to {class:JPEG save options, embed color profile:false, quality:12}
        save thisDocument as JPEG in file myPath with options myOptions appending lowercase extension
                end tell
      end DoSmall
      to DoBig(thisDocument, currentName, initialState)
                          if initWidth < 1020 then
        resize image thisDocument width 1020 resample method bicubic smoother
                          else if initWidth > 1020 then
        resize image thisDocument width 1020 resample method bicubic sharper
                          end if
                                    set wmFile to (path to resource "water_400_white.png" in bundle path to me) as text
                                    set wmFile to (path to resource "water_400_black.png" in bundle path to me) as text
                          end if
        open file wmFile
        translate current layer of thisDocument delta x (myWidth - wmWidth - 16) delta y (myHeight - wmHeight - 16)
                          end if
                          set myPath to (myFolder as text) & (currentName) & "_1020"
                end tell
      end DoBig
