1. Re: Tethered capture issues-5D Mark II a Mac OS 10.6.8
Simon Full Dec 28, 2011 10:12 AM (in response to SF Ellen)Tethered in LR doesn't work great with the 5D on mac in my experience but it should re-detect after a restart at least. Did you switch cables recently? I have 3 USB cables but only one of them works well. Now I use an amplified cable if I need any length more than 1.5 meters.
I don't know what to suggest other than that. I myself stopped using LR to tether a 5D2 with a Mac because, to put it crudely, it's crap with absolutely no consistency.
Now I use C1 Pro with no issues whatsoever, it never fails me and no embarrassing annoyances anymore.
2. Re: Tethered capture issues-5D Mark II a Mac OS 10.6.8
SF Ellen Dec 28, 2011 10:36 AM (in response to Simon Full)I've never had an issue before this, I did try switching out cables, but nothing!
3. Re: Tethered capture issues-5D Mark II a Mac OS 10.6.8
Simon Full Dec 28, 2011 10:49 AM (in response to SF Ellen)I take it you restarted the computer and not just LR? I say this because with my Macbook Pro i noticed on very rare occasions the USB port would fail until i restarted the computer which seemed to juice it up again, if you haven't done a complete shutdown try that. Alternatively test something else in the same port like a printer or phone.
You could load the software called disk utility from canon and try and tether in canon's DPP software.. It should have come on a disc with your camera. If that works then at least we know for sure the problem is with LR.
4. Re: Tethered capture issues-5D Mark II a Mac OS 10.6.8
SF Ellen Dec 28, 2011 10:53 AM (in response to Simon Full)I've restarted everything about six times, AND changed the USB port on my computer. Using the Nikon disk utitlity is a good idea--Ill try that
5. Re: Tethered capture issues-5D Mark II a Mac OS 10.6.8
SF Ellen Dec 28, 2011 10:55 AM (in response to SF Ellen)Sorry--I meant Canon disk utitilty
6. Re: Tethered capture issues-5D Mark II a Mac OS 10.6.8
Seán McCormack Dec 29, 2011 9:29 PM (in response to SF Ellen)Without Lightroom running, open Image Capture on the Mac. Connect the 5DII to the computer. Does Image Capture see it?
7. Re: Tethered capture issues-5D Mark II a Mac OS 10.6.8
SF Ellen Dec 30, 2011 9:44 AM (in response to Seán McCormack)Sean,
This actually did help me. I tried to Image Capture and Lightroom on two different macs, with three different cords. Finally, I went into apple>about this mac>more info> USB and the camera did not show up on either computer. I called Cannon and it seems the port on the camera where the usb plugs in is defective, so I need to send the camera in for repair.
Sigh.
Thanks for all your help!
Ellen
8. Re: Tethered capture issues-5D Mark II a Mac OS 10.6.8
Simon Full Dec 30, 2011 11:03 AM (in response to SF Ellen)You can buy special clip cables that take away the stress from the USB entering the camera by creating a small loop. These are a really good idea as you probably pulled or bent the connection at some point, easy to do.
http://www.shop.tethertools.com/JerkStopper-Camera-Support-JS020.htm
9. Re: Tethered capture issues-5D Mark II a Mac OS 10.6.8
SF Ellen Dec 30, 2011 11:22 AM (in response to Simon Full)Simon,
This is fantastic! I realized too that right before the tethered shooting stopped functioning, I tripped over the cord--not enough to pull anything over but the cord was jerked out of the camera--I am sure that this is when the port became damaged.
This is a great solution! Thank you!
Ellen
10. Re: Tethered capture issues-5D Mark II a Mac OS 10.6.8
monmart Jan 16, 2012 8:00 PM (in response to SF Ellen)For what it's worth, I have a 5D and Lightroom and teathering has never been a problem. I just wish it was faster when displaying the photo. Anyone have any tricks for this?
11. Re: Tethered capture issues-5D Mark II a Mac OS 10.6.8
Simon Full Jan 16, 2012 8:05 PM (in response to monmart)There is no tricks.. it's a USB2 bottleneck for sure as lightroom is only a tad slower than C1.. Cam manafactures need to give us USB3 or Thunderbolt but i don't see that happerning anytime soon. I wish USB2 like Flash would just up and die already.
