4 Replies Latest reply on Jan 1, 2012 4:17 AM by Petzouil31
    Probleme when capturing through AVDC100 on MAC
    Petzouil31 Level 1
      Hi ,
      I get this trouble on 2 Mac Machines ( MACPRO 10.6.8 ) .
      When capturing vhs through Caonpus AVDC1OO , when the signal become low ( make video jumping ) or between scenes ( like nothing between 2 videos on the tape ) , Premiere Stop to capture by itself , even with scenes detection off ...
      Any idea ? it is very boring to stay during 2Hours in front of the display to be sure that it doesn't stop ...
      I used old PP ( 2.0 ) and it doesn't happened , i look through the net , and couldn't find any answer ...
      Thank's for all if you get a solution
      Regards
      Franck
        • 1. Re: Probleme when capturing through AVDC100 on MAC
          Petzouil31 Level 1
          Hi AGain,
          Also sometimes , after 3min 20 Sec it just stop :
          Vidéo still running without default , i don't have the window to save the file , but the time show the acquisition duration stop to increase ( and acquisition aswell )
          I'm probably not clear , but english is not my language , sorry about that .
          I really need help ,cause i get 3 powerfull machine , but very hard to use with this troubles
          Regards
          Franck
          • 2. Re: Probleme when capturing through AVDC100 on MAC
            Petzouil31 Level 1
            Up,
            70 Read , no help ??
            Come on , i read other person having this trouble on the net , i even have , on dv capture , capturing stop if blank scenes betwween 2 others scenes . And i confirme i have not select scene detection and other stuff
            • 3. Re: Probleme when capturing through AVDC100 on MAC
              Stephen_Spider Level 3
              1)  I'm guessing that Caonpus AVDC1OO is an old device, and maybe the drivers are not that good with new systems.
              2)  I don't know if analog to DV converters ever had scene detect. You have to work manually.
              3)  A blank signal will cause DV capture to fail or file corruption on most systems
              • 4. Re: Probleme when capturing through AVDC100 on MAC
                Petzouil31 Level 1
                Hi Stephen ,
                thank's for youer answer ,
                Scenes detect off , i DO NOT select the option to signal when there is corrupt signal , and there is no driver for the AVDC110 ( in fact this is 110 not 100 ) .
                The trouble come with all device i connect , ex : GVD800 ( i can connect analog signal in to get it in the MAC ) , GVD200 or GVD300 ( they are tape player , we can get Analog signal through )
                The things is , that sometimes with the same tape i can get all tape in 1 Rush , sometimes not , and that could even crash Premiere
                i'm confused with this cause on my old systems with PP2.0 , i don't have any trouble for capturing , even DV with blank signal , it just continue till next video on the tape .
                What i want with Premiere ,it is getting ALL tape in 1 rush , comming from analog ( Through a converter - AVDC 110 , Numerique tape player ) or DV Signal ( if i do not select "scenes detection" )
                BTW " Happy new year " to everyone
                Franck
