4 Replies Latest reply on Dec 30, 2011 12:43 PM by Flexpadawan
    Datagrid itemrenderer & evaluation of different column
    Flexpadawan
      Hey All,
      I've been playing with this for a while but can't get it right.  Basically, I have an itemrenderer that has an image and label, but I need to see what the value is of a different column before I know what image to use.  I have a feeling the reason why my intended logic won't work is becasue the data[] does not reporesent the whole data structure...but I could be wrong.
      This is what I have now:
      I have a grid that references this itemrenderer & the grid dataprovider is an array collection:
      Form
      <s:GridColumn dataField="employee"  headerText="Employee"
                       itemRenderer="com.mycompany.view.assets.renderers.EmployeeStatusColour"></s:GridColumn>
      Item Renderer
      <s:GridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
        <fx:Script>
             <![CDATA[
                override public function prepare(hasBeenRecycled:Boolean):void {
                //THIS WORKS BUT NEED TO ADD LOGIC
                     lblData.text = data[column.dataField];
                     statusImage.source = "com/mycompany/view/assets/images/dot_GREEN.png";
                //THIS IS WHAT I WANT INSTEAD - SYNTAX BELOW IS WRONG BUT YOU'LL GET THE IDEA
                     if(data[column(3)]; = "MONDAY"{
                     }else{
                          statusImage.source = "com/mycompany/view/assets/images/dot_BLUE.png";
        </fx:Script>
                <s:HGroup verticalAlign="middle" height="100%" gap="2">
                <s:Image id="statusImage"/>
                <s:Label id="lblData" paddingTop="5"/>
        </s:HGroup>
      </s:GridItemRenderer>
      Thanks in advance to anybody who can direct me to a solution.
      Flex
        • 1. Re: Datagrid itemrenderer & evaluation of different column
          jfb00 Level 3
          Try labelFunction as:
          <s:GridColumn dataField="employee"  headerText="Employee" labelFunction="setColor"
          Here an idea for you function:
          private function setColor(o:Object, c:spark.components.gridClasses.GridColumn):String
                          if (o[c.dataField] == 3){
                              return "dot_GREEN.png";
                          }else
                              return "dot_BLUE.png";
          Best,
          • 2. Re: Datagrid itemrenderer & evaluation of different column
            Flexpadawan Level 1
            I tried your suggestion but it didn't work.   Thanks though!
            However, if you see the code below this works as I stated above.  data[column.dataField] returns the value of the referenced value.
                                                    statusImage.source = "com/mycompany/view/assets/images/dot_green.png";
            So I did a debug inside my item renderer and found that the data object had all the object values of the row from my grid, which is what I want.  I just don't know how to access them individually to do my comparison.  It's probably something really easy like
            If (data[column(4).dataField]=="MONDAY"){
            I know I'm close just don't know the syntax.
            Thanks!
            • 3. Re: Datagrid itemrenderer & evaluation of different column
              Flexpadawan Level 1
              I guess what it boils down to is how to I access the full data reference inside in the GridItemRenderer?
              data[column.dataField] - Returns the cell value of the Column where the item renderer is referenced inside my grid.
              data - Has the whole recordset and I can see it in debug mode, so in my case I need to access the fourth object inside of the data object.  If I can get that problem solved.
              Thanks again!
              • 4. Re: Datagrid itemrenderer & evaluation of different column
                Flexpadawan Level 1
                Found the solution.  Okay, I can go bang my head against the wall now!  lol
                To find any value in the data structure you do the following:
                data[column.dataField="dayStatus"];
