16 Replies Latest reply on Dec 30, 2011 8:01 PM by Keith_Clark
    Time Lapse video
    geldslaw
      I wanted to make a time lapse video and I recorded 19 hours of video but now find I import it into adobe premiere pro but cannot edit it. Is there a way around this as I want to compress the 19 hours down to 10 minutes?
        • 1. Re: Time Lapse video
          What does that mean... what error message(s) do you see?
          • 2. Re: Time Lapse video
            Mortimer IOU Level 2
            There is a way to do time lapse using the posterize time effect, althogh to go from 19 hours to 10 minutes will need some editing as well. So first resolve the "cannot edit" issue. As John said, some more information about your problem might help you get some help here.
            • 3. Re: Time Lapse video
              geldslaw Level 1
              I can import the avi file but cannot drag and drop it on the time line, I get a with a no entry symbol. Also the durartion of the film property says just 3:14 mins etc when I know there's 19 hours of footage there. I wanted to film a Sunrise, Sunset and Sunrise, but the weather became bad so stopped at 19hours.
              • 4. Re: Time Lapse video
                geldslaw Level 1
                • 5. Re: Time Lapse video
                  geldslaw Level 1
                  • 6. Re: Time Lapse video
                    Jim_Simon Level 8
                    That's most likely operator error.  You're doing something wrong, rather than there's something wrong with the video.
                    List out the exact steps you take, beginning with starting Premiere Pro.
                    • 7. Re: Time Lapse video
                      Powered by Design Level 4
                      It sounds like your trying to drop your footage without a sequence open
                      Make sure you have a sequence open that matches your footage.
                      Drag your video to the New Item button and Premiere with create a new sequence matching your footage.
                      GLenn
                      • 8. Re: Time Lapse video
                        geldslaw Level 1
                        Premiere Pro is too simple to make a mistake in. well you can if do not know what you are doing. But obviously I would think that I do. not so long ago I found out that the biggest file that you can edit on premiere pro on windows is 3.? gigs which relates to how much memory windows can address.
                        I was wondering if there was a simimlar issue here with my macbook pro or was it a design issue with premiere?
                        1 I open premiere pro
                        2. I create a new project
                        3 bring in my footage
                        4 create a new sequence
                        but still cannot drag and drop my footage onto the time line. this has happened on two occasions
                        I still after creating a new project, canceling on creating a sequence until I import my movie and then drag it to the new button to create sequence, I am unable to then drag it to the time line
                        • 9. Re: Time Lapse video
                          Since you dragged the video to the new item button I can see it created the sequence for you.
                          You dont need to drag the footage there.  It should just appear there on the timeline.
                          Im wondering since its so HUGE that maybe its conforming the AUDIO and the computer is just going slow ???
                          http://help.adobe.com/en_US/premierepro/cs/using/WS9FAF538A-BEE3-4925-B45A-DF8BE7F2A2E5.ht ml
                          Can you play the video in the Source window ?
                          GLenn
                          • 10. Re: Time Lapse video
                            geldslaw Level 1
                            good point about it should've have thrown it onto the time line but it doesn't and no it doesn't playin the source window. I think there's  limit to the duration of the film that can be placed on the time line. But there has to be a a way around this, what if you were editing a video from a security camera or footage from some science project or basically as I am doing, wanting to creating a times laps movie over of the winter to spring over the next few months?
                            • 11. Re: Time Lapse video
                              Jim_Simon Level 8
                              Hardly.  Premiere Pro is a very sophisticated piece of software, and people have trouble all the time because they're not doing things properly.
                              That's simply not true.
                              • 12. Re: Time Lapse video
                                Jim_Simon Level 8
                                Given the specs of your media file, the problem may simply be that PP can't work with this file.  You should try a normal video clip as a test, to be sure all is well with your installation.
                                • 13. Re: Time Lapse video
                                  geldslaw Level 1
                                  premiere pro works ine with the other films I have recorded with the same digital camera, It's not that I am using a pirate version as I have a legitimate suite that's not even 7 months old. I've been using premiere for the past three years going on 4 years. My use of premiere is simple, you can do complicated things in it but it is simple to use.
                                  Your right, I stand corrected about the file size, it's not premiere but windows that cannot cope with certain files szes, as I had problems copying a hd film that was 10 gigs onto the hard disk and then editing, but I never had the same problem with final cut pro. I will try filming and setting the camera to film at a different quality and see what happens.
                                  thank you for your support so far, happy new year
                                  • 14. Re: Time Lapse video
                                    since you have the suite try opening it up in After Effects and see if it can handle it.
                                    You say you have a 19 hour video that you want to time lapse.
                                    Is this the same file you have in the screen capture ?
                                    The properties say its only 03:14:11:09 unless this is a different file.
                                    Also just curious what camera are you using.  Movie is only 320x240
                                    Post a screen caputure using G-Spot if you can of the file.
                                    http://www.headbands.com/gspot/
                                    GLenn
                                    • 15. Re: Time Lapse video
                                      geldslaw Level 1
                                      the camera has HD quality but as I am only going to show the film on the web, and with using a lower quality setting, I get more hours out of my camera, but I will try a higher setting and see what happens. I am a mac user, so I need an alternative to gspot. Aftereffects cannot deal with the file either. But I think it may be that it is the resolution setting, let me test this tomorrow
                                      • 16. Re: Time Lapse video
                                        Keith_Clark Level 2
                                        premiere timeline tops at 12 hrs or so..... i was trying to do a SD blu-ray here while back and had to use multiple timelines cause 12 or 15 hrs was the max it would allow. try cutting it down and then timelapse, and then putting those timelines into a shorter timeline
