2 Replies Latest reply on Dec 29, 2011 1:26 PM by peter minneapolis
    creating ranges of Numbers
    CoGordo4 Level 1
      I have been asked to create a table where each square has a number. These numbers will count up to a disignated point. Is there a way you can have Indesign Cs5 do this automatically? Something similar to generating page numbers? All these numbers will be on one page.
        • 1. Re: creating ranges of Numbers
          John Hawkinson Level 5
          Yes but you have to cheat. (Some would call that "No.")
          Generate the numbers in Excel and then either paste them into InDesign (sounds like it should work for your table), or for some other kinds of workflows, export them to a CSV file and run data merge, or export to a text file and place as a single story through multiple threaded  frames.
          • 2. Re: creating ranges of Numbers
            peter minneapolis Level 4
            Some of the free InDesign calendar templates use the technique of using a numbered list paragraph style in table cells to create the dates. It works if the numbers are row-wise - left-to-right, then down to the leftmost cell on next row.
            Search Google for terms like "InDesign calendar templates," "and 'InDesign numbered list paragraph styles," without quotes, for more detail.
            HTH
            Regards,
            Peter
            _______________________
            Peter Gold
            KnowHow ProServices
