0 Replies Latest reply on May 29, 2008 10:54 AM by alexenk
    Flex not reading data outputted from PHP + XML
    alexenk
      I have my PHP file which outputs either <loginsuccess>yes</loginsuccess> or <loginsuccess>no</loginsuccess>.
      http://redshiftltd.co.uk/dev/flexlogin/login.php
      ThenI have my MXML to read from the file login.php either the <loginsuccess>yes</loginsuccess> or the <loginsuccess>no</loginsuccess>
      If it returns 'yes' then the state changes to logged in. But the problem is that even if I switch the values over so that by default it presents <loginsuccess>yes</loginsuccess> to try and trick the response, I still get a login failed message.
      Please advise!!
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute">
      <!-- Start of 2nd State, i.e when user has logged in -->
      <mx:states>
      <mx:State name="Logged In">
      <mx:SetProperty target="{panel1}" name="width" value="95%"/>
      <mx:SetProperty target="{panel1}" name="height" value="95%"/>
      <mx:RemoveChild target="{password}"/>
      <mx:RemoveChild target="{username}"/>
      <mx:RemoveChild target="{label1}"/>
      <mx:RemoveChild target="{Submit}"/>
      <mx:RemoveChild target="{label2}"/>
      <mx:SetProperty target="{panel1}" name="title" value="Members Section"/>
      <mx:AddChild relativeTo="{panel1}" position="lastChild">
      <mx:Label x="10" y="10" text="Welcome to the Members Section!"/>
      </mx:AddChild>
      <mx:Label x="10" y="36" text="Here you can do great things, like join the forums @ Viper Creations!"/>
      </mx:AddChild>
      <mx:Label x="10" y="62" text="Label"/>
      </mx:AddChild>
      </mx:State>
      </mx:states>
      <!-- End of 2nd State Code Block -->
      <mx:Script>
      <![CDATA[
      import mx.rpc.events.ResultEvent;
      </mx:Script>
      <mx:Script>
      <![CDATA[
      private function checkLogin(evt:ResultEvent):void
      if(evt.result.loginsuccess == "yes")
      currentState = "Logged In";
      if(evt.result.loginsuccess == "no")
      mx.controls.Alert.show('Invalid username/password');
      </mx:Script>
      <mx:HTTPService id="login_user" result="checkLogin(event)" showBusyCursor="true" method="POST" url=" http://redshiftltd.co.uk/dev/flexlogin/login.php" useProxy="false">
      <mx:request xmlns="">
      <username>
      {username.text}
      </username>
      <password>
      {password.text}
      </password>
      </mx:request>
      </mx:HTTPService>
      <mx:Panel resizeEffect="Resize" width="250" height="200" layout="absolute" title="Login System" horizontalCenter="0" verticalCenter="-2" id="panel1">
      <mx:Label x="10" y="10" text="Username:" id="label1"/>
      <mx:TextInput x="10" y="36" id="username"/>
      <mx:Label x="10" y="66" text="Password:" id="label2"/>
      <mx:TextInput x="10" y="92" id="password" displayAsPassword="true"/>
      <mx:Button x="10" y="122" label="Submit" id="Submit" click="login_user.send();"/>
      </mx:Panel>
      </mx:Application>
