2 Replies Latest reply on Dec 30, 2011 4:52 AM by Dan Macy
    Read XML file with JSX
    Dan Macy
      I would like to be able to read an XML file in an InDesign script and create a new document by looping through its nodes and extracting content from them. I've never done this before and I can't seem to find the right information on how to do it. Can someone give me a snippet to get me started? Thanks!
        • 1. Re: Read XML file with JSX
          Kasyan Servetsky Level 5
          Read the "Integrating XML into JavaScript" chapter in "JavaScript Tools Guide".
          Below is a script I made a while ago. It can give you idea how to start writing your own script. It reads an xml-file, creates a new document from the template, relinks links listed in the xml-file comparing the width, height and resolution with data in the xml-file.
          // Copyright 2011, «Студия Форма»
          // October 3, 2011
          // Written by Kasyan Servetsky
          // http://www.kasyan.ho.com.ua
          // e-mail: askoldich@yahoo.com
          //==================================== GLOBALS ==========================================
          var gErrMsgArr = [];
          Main();
          //=================================== FUNCTIONS  =========================================
          function Main() {
              var montage, doc, docFile, component, noErrors, pdfPath, pdfFile, targetPagesLength, destinationFolder;
              var currentFolder = Folder.selectDialog("Выберите текущую папку");  //new Folder("/D/Evgen/");
              if (currentFolder == null) exit();
              var currentFolderPath = currentFolder.absoluteURI + "/";
              var xmlFile = new File(currentFolderPath + "!sforder.xml");
              if (!xmlFile.exists) exit();
              var outFolderPath = "~/Desktop/Output/";
              var outFolder = new Folder(outFolderPath);
              if (!outFolder.exists) outFolder.create();
              xmlFile.open("r");
              var xmlStr = xmlFile.read();
              xmlFile.close();
              var root = new XML(xmlStr);
              default xml namespace = "http://www.forma-studio.com/order";
              var linksArr = [];
              var componentList = root.xpath("/order/product/components/component");
              var componentsLength = componentList.length();
              for (var c = 0; c < componentsLength; c++) {
                  component = componentList[c];
                  linksArr.push({ name : component.images.image.file_name.toString(),
                                      width : parseInt(component.images.image.size.width),
                                      height : parseInt(component.images.image.size.height),
                                      resolution : parseInt(component.images.image.resolution),
              var montageList = root.xpath("/order/product/montages/montage");
              var montagesLength = montageList.length();
              for (var i = 0; i < montagesLength; i++) {
                  montage = montageList[i];
                  app.scriptPreferences.userInteractionLevel = UserInteractionLevels.neverInteract;
                  app.open(new File(montage.layout_filename));
                  doc = app.activeDocument;
                  docFile = new File(outFolderPath + montage.result_filename + ".indd");
                  doc.save(docFile);
                  app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
                  targetPagesLength = parseInt(montage.page_count);
                  if (!isNaN(targetPagesLength)) {
                      //$.writeln("About to remove pages - " + doc.name + " - " + montage.page_count);
                      while (doc.pages.length > targetPagesLength) {
                          doc.pages.lastItem().remove();
                  UpdateAllOutdatedLinks(doc);
                  noErrors = ProcessDoc(doc, linksArr, currentFolderPath);
                  if (noErrors) {
                      destinationFolder = new Folder(montage.destination);
                      VerifyFolder(destinationFolder);
                      pdfPath = montage.destination + "/" + montage.result_filename + ".pdf"
                      pdfFile = new File(pdfPath);
                      doc.exportFile(ExportFormat.PDF_TYPE, pdfFile, false, "[High Quality Print]");
                  doc.close(SaveOptions.YES);
          function ProcessDoc(doc, linksArr, currentFolderPath) {
              var link, linkFile;
              var noErrors = true;
              var links = doc.links;
          //~     $.writeln("--------------------------");
          //~     $.writeln(doc.name);
              for (var i = links.length-1; i >= 0; i--) {
                  link = doc.links[i];
                  for (var o = 0; o < linksArr.length; o++) {
                      if (link.name == linksArr[o].name) {
                          linkFile = new File(currentFolderPath + linksArr[o].name);
                          if (linkFile.exists) {
          //~                     $.writeln("\t" + o + " - " + linkFile.name + " - linkFile.exists");
                              if (CheckLink(link, linksArr[o], doc) == false) noErrors = false;
                              link.relink(linkFile);
                          else {
                              $.writeln(o + " - " + linkFile.name + " - linkFile doesn't exist");
                              noErrors = false;
              return noErrors;
          function CheckLink(link, linkObj, doc) {
              var errMessage;
              var result = true;
              var image = link.parent;
              var actualPpi = image.actualPpi;
              var md = link.linkXmp;
              var reportFilePath = doc.fullName.absoluteURI.replace(/\.indd$/i, ".txt");
              var width = parseInt(md.getProperty("http://ns.adobe.com/exif/1.0/", "exif:PixelXDimension"));
              var height = parseInt(md.getProperty("http://ns.adobe.com/exif/1.0/", "exif:PixelYDimension"));
              if (actualPpi[0] != linkObj.resolution && actualPpi[1] != linkObj.resolution) {
                  errMessage = link.name + " - resolution is NOT correct: " + actualPpi[0] + "/" + actualPpi[1] + " ppi instead of " + linkObj.resolution + "\r";
                  if (IsInArray(errMessage, gErrMsgArr) == false) {
                      gErrMsgArr.push(errMessage);
                      //$.writeln(errMessage);
                      WriteToFile(errMessage, reportFilePath);
                      result = false;
              if (height != linkObj.height) {
                  errMessage = link.name + " - height is NOT correct: " + height + " pixels instead of " + linkObj.height + "\r";
                      result = false;
              if (width != linkObj.width) {
                  errMessage = link.name + " - width is NOT correct: " + width + " pixels instead of " + linkObj.width + "\r";
                      result = false;
              return result;
          function UpdateAllOutdatedLinks(doc) {
              var link;
              for (var i = doc.links.length-1; i >= 0; i--) {
                  if (link.status == LinkStatus.LINK_OUT_OF_DATE) link.update();
          function WriteToFile(text, reportFilePath) {
              file = new File(reportFilePath);
              file.encoding = "UTF-8";
              if (file.exists) {
                  file.open("e");
                  file.seek(0, 2);
              else {
                  file.open("w");
              file.write(text);
              file.close();
          function GetDate() {
              var date = new Date();
              if ((date.getYear() - 100) < 10) {
                  var year = "0" + new String((date.getYear() - 100));
              else {
                  var year = new String((date.getYear() - 100));
              var dateString = (date.getMonth() + 1) + "/" + date.getDate() + "/" + year + " " + date.getHours() + ":" + date.getMinutes() + ":" + date.getSeconds();
              return dateString;
          function ErrorExit(error, icon) {
              alert(error, gScriptName + " - " + gScriptVersion, icon);
              exit();
          function IsInArray(string, arr) {
              for (x in arr) {
                  if (string.toLowerCase() == arr[x].toLowerCase()) {
                      return true;
              return false;
          function VerifyFolder(folder) {
              if (!folder.exists) {
                  var folder = new Folder(folder.absoluteURI);
                  var arr1 = new Array();
                  while (!folder.exists) {
                      arr1.push(folder);
                      folder = new Folder(folder.path);
                  var arr2 = new Array();
                  while (arr1.length > 0) {
                      folder = arr1.pop();
                      if (folder.create()) {
                          arr2.push(folder);
                      } else {
                          while (arr2.length > 0) {
                              arr2.pop.remove();
                          throw "Folder creation failed";
          • 2. Re: Read XML file with JSX
            Dan Macy Level 1
            That looks very helpful. Thanks very much!
