0 Replies Latest reply on Dec 29, 2011 2:48 PM by jgrm2811
    Can't generate PDF from xdp and XML
    jgrm2811 Level 1
      I'm new to livecycle and flashbuilder.
      I assigned as a task to send to a  livecycle server a xdp template and a XML file with the data in order to create the pdf.
      So far, I created a class with two methods that returns as a BLOB the strings of a xdp template and the XML data to populate the template.
      On the main application I'm calling the generatePDFOutput method from the OutputService and as far as I know I'm supposed to get a Blob which I can manipulate to save it as a PDF.
      What could be my error? or how should I approach this problem? I came here since I can't find some document that shows how to create pdf from a flex app using livecycle...
      I appreaciate your help.
      I attach below the code of the main class
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="initializeChannelSet();">
                  import flash.sampler.Sample;
                  import mx.messaging.ChannelSet;
                  import mx.messaging.channels.AMFChannel;
                  import mx.rpc.CallResponder;
                  import mx.rpc.events.ResultEvent;
                  import services.outputservice.OutputService;
                  import valueObjects.BLOB;
                  import valueObjects.OutputResult;
                  import valueObjects.PDFOutputOptionsSpec;
                  import valueObjects.RenderOptionsSpec;
                  private var parentResourcePath:String="/";
                  private var serverPort:String="";
                  private function initializeChannelSet():void{
                      var cs:ChannelSet= new ChannelSet();
                      cs.addChannel(new AMFChannel("remoting-amf", "http://"+serverPort+"/remoting/messagebroker/amf"));
                  protected function btn_clickHandler(event:MouseEvent):void
                  var pdf:OutputService= new OutputService();
                  var x:TestPDF= new TestPDF();
                  var wsCall:CallResponder= new CallResponder();
                  var out:PDFOutputOptionsSpec= new PDFOutputOptionsSpec();
                  var render:RenderOptionsSpec= new RenderOptionsSpec();
                  wsCall.token=pdf.generatePDFOutput("PDF","Form.xdp","D:\\PDF_Output",out,render,TestPDF.D ata());
                  var res:BLOB= wsCall.lastResult as BLOB;
                  var result:ByteArray= new ByteArray();
                      result=res as ByteArray;
                  var a:Number=2;
                  protected function outputService_resultHandler(event:ResultEvent):void
                      // TODO Auto-generated method stub
              <!-- Place non-visual elements (e.g., services, value objects) here -->
              <mx:RemoteObject id="outputService" destination="OutputService" result="outputService_resultHandler(event);"/>
          <s:Button id="btn" x="90" y="141" label="Button" click="btn_clickHandler(event)"/>
