5 Replies Latest reply on Dec 30, 2011 11:21 AM by Jeff_Coatsworth
    Numbering is out of sequence
    cvgs Level 1
      Using TCS3/FM10/RH9 on Windows XP.
      I have a lot of ordered lists in my procedures.  Some of the steps in the procedures have bullets that have substeps.  For example:
      1  Text
          o Text
             a. text
             b. text
      The next numbered step should be 2.  However, there is something about the substeps (a. and b.) that seems to throw the numbering off.  Instead of getting 2, I usually get 1 again or sometimes I will get a number further down in the procedure.
      I'm linking FM books into my project and everything is numbered correctly in the FM book.
      Here's the HTML:
      <li type="1"><p class="Steps">Do one of the following: </p></li>
      </ol>
      <ul type="disc">
      <li><p class="StepsBullet">If you want to execute the command across
        all running instances of a Sensor role on all logical servers in the
        environment, then select <span style="font-weight: bold;">Broadcast
        Command</span><span style="font-weight: bold;">&#160;&gt; </span><span
        style="font-weight: bold;">Get Option</span>.</p></li>
      <li><p class="StepsBullet">If you want to execute the command on a
        specific instance of a role on a logical server, then do the following
        in the <span style="font-weight: bold;">Sensors</span> panel:</p></li>
      </ul>
      <ol start="1">
      <li type="a"><p class="substep_alpha_a">Select the check box next to
        the Sensor(s) on which you want to execute the command.</p></li>
      <li type="a"><p class="substep_alpha" style="margin-bottom: 17.000pt;">Select
        <span style="font-weight: bold;">Get Option</span> from the drop-down
        list.</p></li>
      <li type="1"><p class="Steps">Click <span style="font-weight: bold;">GO</span>.</p></li>
      Any ideas?  Thanks in advance.
