10 Replies Latest reply on Jan 8, 2012 5:30 PM by RjL190365
    OCZ Vertex3 for laptop system disk - or not
    pejaka
      I'll soon get a new laptop and I plan to change the original 750 GB system disk to OCZ Vertex 3 120GB.
      I'm going use the laptop for Production Premium CS5.5 and InDesign CS5.5 when I travel.
      Is the 120 GB size enough for system disk and Adobe programs?
      I'll buy another 750 GB and make external USB3 (R)aid0 set for material and projects.
      I have noticed here some concerns about OCZ SSDs, is there any reason to avoid that brand?
      I just have one spare OCZ waiting to get to the real work....
      pena
        • 1. Re: OCZ Vertex3 for laptop system disk - or not
          Harm Millaard Level 7
          For a laptop a SSD makes sense, provided you have another internal SATA 7200 disk and some eSATA externals or in the worst case USB3 externals. OCZ does not have a great reputation. A Crucial M4 may be way better.
          • 2. Re: OCZ Vertex3 for laptop system disk - or not
            JEShort01 Level 4
            Pena,
            Yes, avoid OCZ and others with a SandForce controller for now; the number of firmware updates and serious user complaints are too high for something so mission critical as your OS/program drive for a laptop. Crucial (C300 or M4) and Intel (320 or 510) are both excellent choices and still perform very well for your intended purpose.
            Even if you don't go with a larger laptop that can hold 2 or 3 2.5" drives, many laptops can take a SATA connected 2.5" drive bay in the optical bay slot. You would have to more your optical drive to a cable connected configuration, but personally I think this is more desireable than having the optical in the laptop and having to have a connected drive any for your data. Check out newmodeus.com if your laptop vendor does not have this option.
            Jim
            • 3. Re: OCZ Vertex3 for laptop system disk - or not
              I use 51Gig for Win7 64bit Pro + CS5 Master Collection + MS Office 2007 + all other 'misc' software I use
              120Gig is plenty large
              • 4. Re: OCZ Vertex3 for laptop system disk - or not
                pejaka Level 1
                Thanks Harm,  Jim and John for your help.
                The laptop should have space for 2 HDDs and if  I take the optical drive off as Jim said for three drives.
                What worries me a little is the heat and the power supply.
                Next monday or tuesday when I get the laptop (MSI GT683DX) I'll make my plan.
                pena
                • 5. Re: OCZ Vertex3 for laptop system disk - or not
                  JEShort01 Level 4
                  Pena,
                  Regarding 2 drive capacity with your laptop, that is excellent!. I'd go:
                  1st drive - 120GB or 128GB SSD
                  2nd drive - 500 or 750GB HD
                  optical bay - Blu-ray or DVD burner
                  USB 3 - use for CS5/5.5 media cache, media cache DB, and render outputs to speed things up considerbly; also, if you are ever needing to run things without the USB 3.0 connected, you still can, it will just be a bit slower.
                  Regarding heat and power supply, that is a concern when CS5/5.5 is really working hard, however the big users of power and causes of heat are the CPU and GPU.
                  Jim
                  • 6. Re: OCZ Vertex3 for laptop system disk - or not
                    Dvico
                    Hi pejaka!
                    Be carefull with OCZ Vertex 3. 2 months ago I returned my 240GB Vertex 3, because totally dead after 3-4 months.I used in my desktop for Premiere Media cache and preview files.
                    Now it was Christmas time I went to countryside with my laptop, where I also used OCZ vertex 3 for system drive.3 days ago this ssd also completely dead.
                    First time I got back my money, and I bought corsair Force 3.Till now still works.Good luck.
                    • 7. Re: OCZ Vertex3 for laptop system disk - or not
                      FelixUnderwood Level 2
                      I have had great success with multiple Crucial SSDs and am about to venture into the world of Corsair Force Series 3. Both brands use the Marvell controller, which has been very reliable and trouble free. Oh yeah, and very fast! Something's up with the SandForce controller and Sandybridge.
                      • 8. Re: OCZ Vertex3 for laptop system disk - or not
                        pejaka Level 1
                        Thank you all for your advices. I decided not to gamble with my OCZ. I read some firmware update pages and that looked so scary that I decided just to let it be.
                        I just got my new laptop, MSI GT683 and it has WD Scorpio Black 750GB as a system disk with Win7 Home 64 preinstalled. So I keep it and just fill all the four memory slots with
                        4 GB DIMMS. Also I add another HDD inside the chassis - yes it has an empty place for another Sata HDD.
                        Maybe later when I have more time and money I'll upgrade the system disk to SSD with Win7 Pro 64 and change the 4GB DIMMs to 8G ones.
                        One more thing about my OCZ:
                        This new laptop has also eSata connector. I have HDD docking station with eSata and USB2 connectors. I took my OCZ Vertex3 disk and connected the docking station with eSata to laptop.
                        A saw the normal brief info-flash "OCZ Vertex3.." but then nothing. The disk did not come in sight. I changed to USB2 connector, same problem.
                        Then I connected the docking station to my desktop PC, immediately the disk appeared.
                        Something is really up...
                        Maybe SSD with Marvell controller is the way to go, thanks Felix.
                        pena
                        • 9. Re: OCZ Vertex3 for laptop system disk - or not
                          pejaka Level 1
                          My laptop is now up and running.
                          The laptop is MSI GT683DX, now little modified:
                          i7-2670QM, GTX 570M (hack), 16GB RAM.
                          I bought Intel SSD 320 120 GB as a system/program disk and original WD Scorpio Black 750 GB as a data disk.
                          I also have external 2.5 inch USB3 and eSata disks as backup. Maybe I can use them for media cache and exports as Jim proposed.
                          So far everything looks good enough.
                          PPBM scores  "103","194","95","8" from Scorpio Black.
                          The scores were little better from SSD only, but this is working combination.
                          pena
                          • 10. Re: OCZ Vertex3 for laptop system disk - or not
                            RjL190365 Level 5
                            pena,
                            That 400-second total time result is quite typical for an i7-26xxM series CPU, which (for the most part) does not have quite enough clock speed compared to its desktop siblings that have similar-looking model numbers. In fact, it is below the result I had achieved with even a default-speed, Turbo-Boosted i5-2400 desktop PC with a similarly fast hard disk.
