1 Reply Latest reply on May 29, 2008 9:06 AM by kindaian
    Resolution Xtra and secondary monitor
    Level 7
      Hi
      I'm using Resolution xtra to change the resolution on my monitor
      My PC with windows XP has 2 monitors
      And when I change resolution for primary monitor, using function
      cSuccess =
      gResXtra.set_resolution(cResWidth,cResheight,cResMode,gResXtra.get_primary_display())
      then resolution on secondary monitor is also changed. I'm not sure but it
      can be that resolution on secondary monitor changes to some other dimentions
      as on primary monitors
      Any suggestions?
      Any help will be appreciated
      game_dev
        • 1. Re: Resolution Xtra and secondary monitor
          kindaian Level 1
          Depends ALOT...
          There are graphic cards where the resolution set in the first monitor must be equal to the second, and so the driver itself will adjust the second one when the primary one is changed.
          On windows can you set-up different resolutions? Or are the resolutions linked up? [one way to link them is to have a "wide" virtual monitor that some other drives allows to configure]
          Hope it helps,
          Kindaian
