3 Replies Latest reply on Feb 21, 2014 1:40 PM by bryan.gough
    composition: duplicate and "make unique"
    lmaclanphere Level 1
      hi all
      I am curious if there's a way in AE to duplicate a comp, then somehow "make unique", so that changes to the duplicate don't effect the original--
      so far, I've been copy/pasting layers from the original into a newly created comp, and this seems to do the trick.. but perhaps there's a quicker way?
      thanks!
      LML
        • 1. Re: composition: duplicate and "make unique"
          Just duplicate the comp in the Project Panel by selecting the composition and pressing Ctrl/Cmnd + D. This will give you a unique copy. You can re-name it and change everything in it without changing the original.
          If there is a precomp in the original then changing something in the pre-comp will make a change in every comp that contains the pre-comp.
          You can also duplicate the precomp, re-name it, and then replace it in the the timeline of whichever comp you want. You do this by selecting the precomp in the timeline, then selecting the duplicate pre-comp in the Project Panel, then while holding down the Alt/Option key, you drag the duplicate to the timeline and release. This is the standard technique for replacing footage in a timeline.
          • 2. Re: composition: duplicate and "make unique"
            thanks very much Rick, that seems to work
            so it looks like you do have to actually replace the comp (alt+drag), not just add a duplicate from the project panel--or else the animation/effects get cleared out?
            LML
            • 3. Re: composition: duplicate and "make unique"
              bryan.gough Level 1
              IS there a way to do this via scripting? For example... I have a calendar grid formed by a solid square and a text object for the number. I'd like to generate these calendars without having to make a unique "day" comp for each instance.... does that make sense?
