2 Replies Latest reply on Jan 1, 2012 11:59 AM by nealeh
    Adjusting Date/Time in PE10 works differently for images vs. videos
    JMBinCO Level 1
      I can adjust the date/time in PE10 Organizer for any file. The reason do this is to get photos or videos that were shot with incorrect dates/times to match up correctly in date/time to others. This can happen when you forget to update your camera's time or when on travel. You may also process or convert a video file into another format. This does not preserve the date of the original file.
      However, if you update the thumbnails, or simply move files/folders, or upgrade versions/catalogs etc., then the dates changes are not preserved. PE only saves the dates/times adjustments to the external file - modified file date/time. However, it only does this for .jpg (or photos). It does not change the video file date/times.
      So why behave differently for photos vs. videos?
