0 Replies Latest reply on Jan 2, 2012 3:26 AM by xllopes
    Number display in a calculator
    xllopes
      I am new to actionscript and Flash, and I have been doing a tutorial on how to build a calculator.
      It all seems to be working fine, except that the numbers aren't showing in the display window, well any number except for "0", zero is showing just fine.
      This is the code I have so far (following the tutorial):
      var numbers:Array = [num0Btn,num1Btn,num2Btn,num3Btn,num4Btn,num5Btn,num6Btn,num7Btn,num8Btn,num9Btn];
      var operators:Array = [divideBtn,addBtn,subtractBtn,multiplyBtn,equalBtn];
      var op:String;
      var num1:Number;
      var num2:Number;
      function addListeners():void
          for(var i:uint = 0; i < numbers.length; i++)
              numbers[i].addEventListener(MouseEvent.CLICK, pressNumber);
          for(i = 0; i < operators.length; i++)
              operators[i].addEventListener(MouseEvent.CLICK, pressOperator);
          clearBtn.addEventListener(MouseEvent.CLICK, clearAll);
          dotBtn.addEventListener(MouseEvent.CLICK, addDot);
      function pressNumber(event:MouseEvent):void
          var instanceName:String = event.target.name;
          var numPushed:String = instanceName.charAt(3);
          trace(instanceName);
          trace(numPushed);
          trace(windowTxt);
          var texto:String = windowTxt.text;
          trace(texto);
          if(windowTxt.text == "0")
              windowTxt.text = "";
          windowTxt.appendText(numPushed);
          trace(windowTxt.text);
      function pressOperator(event:MouseEvent):void
          var currentOp:String = instanceName.slice(0, instanceName.indexOf("B"));
          trace(currentOp);
      function clearAll(event:MouseEvent):void
          windowTxt.text = "0";
          num1 = NaN;
          num2 = NaN;
      function addDot(event:MouseEvent):void
          if(windowTxt.text.indexOf(".") == -1)
              windowTxt.appendText(".");
      addListeners();
      For example I have tried out the calculator, inserting some numbers and this is part of what is traced:
      6
      [object TextField]
      12036803259
      120368032596
      num3Btn
      3
      [object TextField]
      120368032596
      1203680325963
      num0Btn
      0
      [object TextField]
      1203680325963
      12036803259630
      so I know this is working, the only problem is that at this point point the only thing in the display window is "000".
      The properties of windowTxt are: Classic Text and Dynamic Text
      I have tried it with different fonts, but still isn't working
      Thanks in advance for any help you can provide me.
      Best regards
