2 Replies Latest reply on Jan 2, 2012 9:37 AM by pgice
    Need Help with Time Warp
    pgice
      HI all!
      i have two problems that i cant solve
      first is that if i use timewarp with slowmotion on a video the video is shorteining so i miss the end.
      how do i increse the video so i can add time warp speeds at 10% without loosing the end of the video?
      i have tried to strech the time of the video but no difference
      i have also set the duration for several minutes longer but no go.
      how do i solve this?
      problem nr 2:
      is there a way to sync the pitch of the audio so it follows the timewarp?
      as now the audio keeps running at the same speed even if the video is in slow motion.
      here is the result of the video so far without sound
      its from Battlefield 3.
      http://privat.bahnhof.se/wb192876/Gulf%20of%20Oman%20Time%20Warp.mp4
        • 1. Re: Need Help with Time Warp
          Pre-compose to a composition of suitable duration, then warp the comp.
          Well, you'd have to use separate time-remapping. Timewarp is just an effect and only processes pixels. Anyway, AE sucks at audio processing and it will neitehr be particularly intuitive nor will the quality be any good. Use an audio program. And generally don't expect miracles - slowing down things down that much is bound to cause glitches both in the picture and audio parts.
          Mylenium
          • 2. Re: Need Help with Time Warp
            pgice Level 1
            thanks for the answer
            i will try it
            to bad with the audio but i understand the problem
