5 Replies Latest reply on Jan 3, 2012 11:38 AM by FrancescoComp
    Photoshop Problem on launch
      I've Photoshop CS5.1, the problem is that when i launch Photoshop, it doesn't even appear the splash screen, it just appears:
      "Adobe Photoshop had stopped working"
      The details of the error are:
      Problem Event Name:APPCRASH
        Application Name:Photoshop.exe
        Application Version:
        Application Timestamp:4d90cf71
        Fault Module Name:KERNELBASE.dll
        Fault Module Version:6.1.7600.16850
        Fault Module Timestamp:4e21132b
        Exception Code:c06d007e
        Exception Offset:00009673
        OS Version:6.1.7600.
        Locale ID:1040
        Additional Information 1:0a9e
        Additional Information 2:0a9e372d3b4ad19135b953a78882e789
        Additional Information 3:0a9e
        Additional Information 4:0a9e372d3b4ad19135b953a78882e789
      I have installed some Red Giant Software Plug-Ins recently, but when i deleted the folders, the error was still there!
      Any solution?
        • 1. Re: Photoshop Problem on launch
          Curt Y Level 7
          Your problem lies with the default module KERNELBASE.dll.  This is not an adobe but an OS problem.
          Google that and see what you can come up with.
          • 2. Re: Photoshop Problem on launch
            Level 7
            Crashes like that are usually due to drivers: video, printer, scanner, camera, etc.
            What changed on your system since it was last working?
            Yes, sometimes they can also be caused by third party plugins (try disabling all third party plugins to check).
            • 3. Re: Photoshop Problem on launch
              FrancescoComp Level 1
              I deleted all the third party plugins but still doesnt work.
              I don't really remember what changed, I have Uniblue Powersuite that has a tool that automatically updates all the drivers, and it doesn't say anything strange... I don't really know!
              • 4. Re: Photoshop Problem on launch
                jiten rai Level 1
                there might be a permission issue .so try enabling the admin account and then work with the same
                • 5. Re: Photoshop Problem on launch
                  There actually is an issue with switching my bad kernelbase.dll with the good one...
                  I downloaded a normal copy of KernelBase.dll, but i can't manage to delete the bad one, for then put the good copy in the right place!
                  I tried with this command:
                  del C:/Windows/System32/KernelBase.dll
                  And it didn't work
                  So i tried this one, with the command to force:
                  del /f  C:/Windows/System32/KernelBase.dll
                  And it didn't work either,
                  I tried to run Windows 7 in safe mode to actually access to it and run the CMD and put those commands in, but it just doesn't work!
                  The problem is that i deleted the Photoshop Setup file, so i don't really know how to fix this problem, and i don't either now if reinstalling is prossibly going to fix it.
                  Thank you for support.
