1 Reply Latest reply on Jan 3, 2012 5:23 AM by kmkarthic
    Issue with adding label to <s:HGroup>
    kmkarthic
      Hi All,
      I've reqmt to diplay a column which takes multiple values seperated by coma like abc,def,ghi etc. And when mouse is hovered over each value the corresponding description shuld come in a tootltip.
      I guess there is some problem in addElement method. Right now empty values are displayed.
      override public function set data(value:Object):void{
          _data = value;
          if(_data!=null){
           if(column.dataField == "XXXX"){
            _dataArrCollection = _data[column.dataField];
            var featureLabel:HGroup = new HGroup();
            var lblDots:Label = new Label();
            lblDots.text = "";
            lblDots.toolTip = "";
            if(_dataArrCollection != null ){
             for(var i:Number = 0; i < _dataArrCollection.length; i++)
              var lblData:String = StringUtil.trim(_dataArrCollection[i]["featureCode"]);
              if(i < (_dataArrCollection.length - 1))
               lblData += ",";
              var lbl:Label = new Label();
              lbl.text = lblData;
              lbl.toolTip = _dataArrCollection[i]["featureDesc"];
              // this.addElement(lbl);
              featureLabel.addElement(lbl);
              featureLabel.horizontalAlign = "left";
              totalLabels += 1;
              lblDots.toolTip += _dataArrCollection[i]["featureCode"] + " : " + _dataArrCollection[i]["featureDesc"] + "\n";
            //this.addElement(lblDots);
            featureLabel.addElement(lblDots);
            totalLabels += 1;
      When used this.addElement(lblDots) instead of   adding the label to a HGroup element like  featureLabel.addElement(lblDots);, values are getting displayed but overidden (wrapped on) on each other.
      Any help much appreciated.
