0 Replies Latest reply on Jan 3, 2012 7:50 AM by L_Umphrey
    Error 103:103 - Abode Reader 10.1.1  & IE 9
    L_Umphrey
      Only two ways I found around this issue when opening Pdf's in IE 9,
      • select "save target to a file"; probably the safest method - one that allows you to view it at your pleasure,
      • or disable the the protected mode by opening Adobe Reader, Edit Preferences, General tab, "uncheck" enable protected mode at start up, close Reader, restart Reader
      Only two methods I found that allows me to view Pdf's when using IE 9 under Vista - oh yes - if i can't get it to work under Vista, nothing else gets it! I rather have one "screwed up"
      than a bunch of them. If anyone else has other ideas to get around the error 103:103 code or perhaps the correct way to resolve it, go for it! At least this works until the next update!
      Good luck!
