3 Replies Latest reply on Jan 3, 2012 5:09 PM by Bo LeBeau
    Identifying which Layer is a template from Printing Company?
    RN12
      I've taken over a graphic design position, and am having a it of trouble with something simple. For a 28 page catalog, the printing company has told me that my predecessor's uploaded files (PDF's exported from .indd) contains their (the printing company's) template guidelines (rules for bleed, trim etc.). It looks like the standard procedure before I took over was to download the rule/guideline template from the company and simply apply it on our own InDesign file as a layer. They have told me that one of the layers in my InDesign file still contains the template guidelines, which show when printing. My predecessor thinks that the culprit layer is in the Master page, and while the two layers on the Master are there (one titled "Rule Border" one titled "Mask-1") one is a small blank box (moveable) and the other is a large (page size, locked) blank box. When I hide these layers or deselect the "Print Layer" or "Show Layer" options, artwork/content is deleted from multiple pages. Is there any way to identify which layer is which, or to view the properties/contents of each individual layer (specifically these blank boxes on the Master page)? OR is there a better solution? PLEASE HELP
        • 1. Re: Identifying which Layer is a template from Printing Company?
          Layers are global, so if you turn them off one place, they are turned off everywhere.
          Also, the layers panel has changed radically starting in CS5, so you now actually can see what is on each layer, a la Illustrator, and show/hide individual objects (which are not global -- they live onthe layer on a particular page, which might or might not be the master).
          Fastest way to find something is to open a page where it shows and try to select it, then look in the layers panel. If you can't select it, either it's locked (also visible in the layers panel, or it's on a master page).
          • 2. Re: Identifying which Layer is a template from Printing Company?
            Joel Cherney Level 5
            Which layer is which? Well, if you are in View -> Screen Mode Normal and have turned on View -> Extras -> Show Frame Edges, then every frame on the page has a color, and the color is defined in the Layer Properties.  (Screenshot didn't catch my mouse pointer, I had to draw it in...)
            • 3. Re: Identifying which Layer is a template from Printing Company?
              Bo LeBeau Level 4
              Often when printing companies have a template for people to download it is usually not an InDesign template file.
              Is is often a graphic; an EPS, PDF,Tif, or Jpg that can be placed on a layer to make sure elements are placed correctly.
              Since this is probably one of these, try looking in the Links Manager for something with an unusual name that might be the template.
              The Links Manager can tell you on which page it resides.
              If you select the linked file in the list and click the page # to the right or the Go to Link icon at the bottom (Page icon with an arrow) it will go directly to the page and the item will be selected.
              We don't know how it was originally placed, it might not even be on a Master Page. It might have been placed on Document pages, maybe even more than once.
              Once you have determined where it is, the quickest way to hide this is to create a completely new layer and call it something like  "Template - HIDE THIS!"
              Drag the selected template image (and only the template image) to the new layer in the layers panel.  As Joel Cherney has show above. the highlighted item on the page will have a colored dot to the right in the layer.
              Drag this dot to the Template layer and the linked item will be moved there. You can then hide or delete the template layer.
              It is also a good idea to LOCK any template layer since locking it will prevent you from accidently placing or moving elements onto this template layer!
