This content has been marked as final.
Show 3 replies
1. Re: unable to install InDesign CS5.5
John Hawkinson Jan 3, 2012 6:41 PM (in response to uminds)It's the same installer for all Windows variants, 32- and 64- bit. Try http://www.adobe.com/support/loganalyzer/ for help with the failed install.
2. Re: unable to install InDesign CS5.5
P Spier Jan 4, 2012 4:41 AM (in response to uminds)You may also want to try calling tech support. There is no charge for help with installation issues of the current release if your system meets the minimum requirements.
3. Re: unable to install InDesign CS5.5
uminds Jan 5, 2012 10:00 AM (in response to P Spier)Thanks, the problem was that I installed the programs from a network drive. As soon as I copied the files into the local drive and installed it from there, everything it fine. It is strange that it worked for the 32bit Windows even though it is from a network share.
Keith
