1. Re: PLEASE HELP! PP will not compile my timeline??????????????
John T Smith Jan 3, 2012 5:04 PM (in response to Stevedocmaker)Since you don't provide much in the way of detail... here are some general guesses
As well as the below, right click the Encore icon and select Run as Administrator, which is NOT the same thing as running the computer with the Administrator account, and which fixes several "odd" problems... To create a dual layer DVD (or a BluRay?), you MUST have Encore set to use the Run as Administrator option
Run as Administrator http://forums.adobe.com/thread/771202
Odd Errors http://forums.adobe.com/thread/670174
Long File Names or odd characters cause problems
Read http://forums.adobe.com/thread/588273
And #4 http://forums.adobe.com/thread/666558
And This Message Thread http://forums.adobe.com/thread/665641
Things and Software to AVOID when authoring/burning a DVD
Start --> http://forums.adobe.com/thread/608660
#2 has WHY Explained http://forums.adobe.com/thread/607390
Plus http://forums.adobe.com/thread/562941
Create an ISO (Encore) or folder on your hard drive (Encore or Premiere Elements) and then use the FREE http://www.imgburn.com/index.php?act=download to write files or folders or ISO to disc (send the author a PayPal donation if you like his program)
Photo Scaling for Video http://forums.adobe.com/thread/450798
-Too Large = Crash http://forums.adobe.com/thread/879967
Firewall = Crash http://kb2.adobe.com/cps/857/cpsid_85711.html
Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
What is a CODEC... a Primer http://forums.adobe.com/thread/546811
What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
For Mac http://mediainfo.massanti.com/
And a comment... every day that ends with no problems... do a project "save as" with an incremental project name... movie001... movie002... and so on... so problems may be bypassed by going back a version or two
2. Re: PLEASE HELP! PP will not compile my timeline??????????????
Stevedocmaker Jan 3, 2012 5:20 PM (in response to John T Smith)If you read carefully, you'll see that the problem is not with Encore or in the DVD burning process. It's within Premiere, I can't even render a section of my timeline without getting the error message. It seems to be happening in one section of the timeline, as previous exports and renders all seem to stop at around the same place. I'm checking into what's there and I will report back if I can figure this out.
Steve
3. Re: PLEASE HELP! PP will not compile my timeline??????????????
Stephen_Spider Jan 3, 2012 5:44 PM (in response to Stevedocmaker)1) reboot.
2) Try opening an autosave version from a previous session, Export out a master\backup version of your program.
4. Re: PLEASE HELP! PP will not compile my timeline??????????????
shooternz Jan 3, 2012 6:06 PM (in response to Stevedocmaker)Something I would do first ., after checking that section...is delete all the render files. (Menu Option - not manually)
Next...
I would try opening my Back Up file.
I would next try importing the project into a fresh new project.
Hopefully step 1 helps.
5. Re: PLEASE HELP! PP will not compile my timeline??????????????
Stevedocmaker Jan 3, 2012 8:28 PM (in response to shooternz)Guys, thanks for all your suggestions.
The problem appears to be with a nested sequence. Why it transcoded a few days ago, I can't answer. But after trying your suggestions to no avail, I followed a hunch, experimenting by exporting sections of the timeline. In doing this I was able to narrow the problem down to one spot. There was a nested sequence in that spot, and being ALL TOO AWARE of the bugginess of this "feature", I unlinked the clip, and replaced the audio for that section with and AIFF file rendered from the original sequence. That appears to have done the trick.
I hope SOMEONE at Adobe, someone who has some authority to tell what the programmers to work on that is, is monitoring this thread. In case they don't get it, I'll spell it out for them:
NESTED SEQUENCES DO NOT WORK.
6. Re: PLEASE HELP! PP will not compile my timeline??????????????
lasvideo Jan 3, 2012 8:42 PM (in response to Stevedocmaker)Steve, how about doing in a manner they will hear you and do get detailed about your issue.
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
7. Re: PLEASE HELP! PP will not compile my timeline??????????????
Stevedocmaker Jan 3, 2012 9:07 PM (in response to lasvideo)Thanks, but I reported my problems with nested sequences MONTHS ago and never heard a peep. But I'll do so again anyway.
Steve
8. Re: PLEASE HELP! PP will not compile my timeline??????????????
Kevin-Monahan Jan 4, 2012 11:26 AM (in response to Stevedocmaker)Hi Steve,
If the nested sequence worked in your earlier export, something tells me that the sequence got corrupted at some point. This happens from time to time in all NLEs, particularly on projects that are complex, long, or have been in use for some months. As a safety, it helps to back up your sequences by duplicating them (including nested sequences) periodically. This ensures that you always have a back up for your main sequences (and nested sequences) in case something goes awry.
Nested sequences do work, and are very handy in many operations. However, they are subject to corruption - as are all sequences and clips. In any case, I'm glad you figured it out.
10. Re: PLEASE HELP! PP will not compile my timeline??????????????
Stevedocmaker Jan 4, 2012 1:12 PM (in response to Kevin-Monahan)Thanks for the input Kevin. I have to say, I've had trouble with nested sequences from the get-go. I'm using AVCHD, h.264/Canon and prores source files. Unless I monkey with the audio tracks, the program wants to "render required files" every time I hit the space bar. Seems like there's lots of room for improvement here.
