3 Replies Latest reply on Oct 21, 2015 5:52 AM by Colin Flashman
    DATA MERGE - Excel format CSV Data Source
    viacacao
      Hi I'm trying to build a catalog with DATA MERGE and every time I select the Data Source (Excel file with all the details) an error occurs. Seems that the CSV file is not properly constructed.
      Can you show me a sample of a better excel file that provide an info "catalog" format?
      Thanks so much,
      Best,
      Vanessa
        • 1. Re: DATA MERGE - Excel format CSV Data Source
          Are you trying to use an excel file (.xls or .xlsx) as the data source? You have to actually save the file into either .csv or tab-delimited text format (although both of those will open in Excel, they are really plain text files that can be opened in any text editor) to use as a data source.
          What's your OS? What error message do you see, if any?
          • 2. Re: DATA MERGE - Excel format CSV Data Source
            bobtap
            When using data merge always ensure your targeted data base file is closed!!
            Data merge will not work if the targeted file is open in the original program
            • 3. Re: DATA MERGE - Excel format CSV Data Source
              Colin Flashman Adobe Community Professional
              Making sure the database is closed isn't always the catch-all answer to data merge error dialogs. I've found at least eight different dialogs that can be associated with data merge errors and they range from these dialogs:
              1. The selected data source has one or more empty field names. Please fix the file or select another file
              2. The data source cannot be opened. Confirm that the file exists and that you have rights to open it, then choose the Select Data Source command again.
              3. There is at least one data placeholder that cannot be found in the data source. Make sure all the placeholders correspond to the fields in the data source.
              4. The data source file you selected either has no records or is not a supported file format. Please fix the file, select a file that contains records, or select a supported file type.
              5. Content contains characters which cannot be encoded
              6. Generic extended parser error
              7. The data source references one or more missing images. The missing images cannot be previewed or merged. At the time you create a merged document, you can choose to generate a list of all missing images.
              8. Not well-formed
              If a user exported their data from excel to a csv or txt file BUT did not close the file AND then attempted to select a data source, THEN the second dialog would appear.
              Also, I can have the database open in the application "textwrangler" on my mac and still select it as a source data file in InDesign's Data Merge. The above error looks specific to Excel, but I'm sure it'll happen with other software.
              That said, in answer to the OP's question, I believe the answer may relate to something else, such as having a colon in the middle of a field name. Anyone can reproduce this fault by copying the code below into a text editor and then select it as a data source for a data merge:
              name,suburb,post:code
              John,Adelaide,5000
              Craig,Calgary,T9Y 7B3
              Max,Sydney,2000
              a different error will occur if there are two colons:
              name,suburb,pos:t:code
              John,Adelaide,5000
              Max,Sydney,2000
              remove the colons and it works:
              name,suburb,postcode
              John,Adelaide,5000
              Max,Sydney,2000
              interestingly, if the colons are at the start, end (or both) of a field name, then it will work too:
              name,suburb,:postcode:
              John,Adelaide,5000
              Max,Sydney,2000
              But because the OP didn't provide a screenshot of the error, not did the OP write the exact wording of the error down, we won't quite know what happened.
