0 Replies Latest reply on Jan 4, 2012 11:44 AM by bon_t
    Issue with capturing shortcut keys
    bon_t Level 1
      Hi All,
      I am using Adobe Flash Builder 4.0.1.
      In my application, there is a module that allows a user to listen to an audio file and transcribe what he hears. We have the following two shortcut keys (among others): Ctrl + Space to play the audio file and Ctrl + Enter to save the transcription.
      Two components of this module are TranscriptionText.mxml (creates the Editor window in which to type the transcription) and ShortCutKeyDispatcher.as (which is misleading; it doesn't dispatch the shortcut key event, it actually handles it).
      In ShortCutKeyDispatch.as, there's the following code:
      public function registerTranscription(transcription:TextArea):void
           if (_transcription != null || transcription == null)
                throw createUsageError();
           log("Register text area");
           _transcription = transcription;
           FlexGlobals.topLevelApplication.addEventListener(K  eyboardEvent.KEY_UP, keyHandler);
      private function keyHandler(event:KeyboardEvent):void
           if (GlobalProperties.INSTANCE.formId != formId)
                return;
           log("Handle key " + event.keyCode);
           var bCtrlPressed:Boolean = event.ctrlKey;
           var bShiftPressed:Boolean = event.shiftKey;
           var curCharCode:int = event.charCode;
           if ( bCtrlPressed && bShiftPressed )
                switch ( curCharCode )
                     case 40:  // 40 is the charcode value for '('
                          transcription.insertText("[g] ");
                          break;
                     case 41:  // 41 is the charcode value for ')'
                          transcription.insertText("[q] ");
                          break;
           else if (bShiftPressed)
                     case 32:  // 32 is the charcode value for Space
                          // Reset audio position to beginning
                          removeLastCharFromTranscript( curCharCode );
                          setTrackPosition(0);
                          break;
           else if (bCtrlPressed)
                switch (curCharCode)
                     case 13:  // 13 is the charcode value for Enter/Return
                          // Send current transcription (Save)
                          saveTranscription();
                          break;
                          if (playing())
                               pauseAudio();
                          else
                               playAudio();
                          break;
                     case 44:  // 122 is the charcode value for ','
                          rewind();
                          break;
                     case 46:  // 120 is the charcode value for '.'
                          fastForward();
                          break;
                     case 91:  // 91 is the charcode for '['
                          changeValueByStep(false); // decrease the audio volume
                          break;
                     case 93:  // 93 is the charcode for ']'
                          changeValueByStep(true); // increase the audio volume
                          break;
                     case 59:  //  59 is the charcode value for ';'
                          transcription.insertText("[n] ");
                          transcription.dispatchEvent(new TextOperationEvent(Event.CHANGE));
                          break;
                     case 39:  //  39 is the charcode value for '''
                          transcription.insertText("[c] ");
                          break;
                     case 47:  // 47 is the charcode value for forward slash
                          transcription.insertText("[u] ");
                          break;
      The issue is that, when the two keys (Ctrl + Space or Enter ) are pressed very quickly (as should be expected), the expected action is not performed. To debug, I put a breakpoint at the beginning of the keyHandler logic above. When the app stopped at the breakpoint, I see that event.ctrlKey = false and event.charCode = 0 (not event.ctrlKey = true and event.charCode = 13 or 32)! I ran the app and it stopped at the breakpoint again (I wasn't expecting this). This time, however, event.ctrlKey = false still BUT event.charCode = 13 or 32. Every now and then, the app stopped at the breakpoint a third time, and this time event.ctrlKey = true.
      So I am confused. The code is detecting the "key pressed" event, but there seems to be a delay in the pertinent values being updated. If we hold down the Ctrl key a little longer, and then press and hold down a little longer the Space or Enter key, then it works about 90% of the time.
      Your help is greatly appreciated!
      Bon :-D
